0 Members and 2 Guests are viewing this topic. Read 141959 times.
Vinnie, forgive me if this is an ignorant question. Aren't the Dual Burr Brown PCM1795 d/a chips only used for playback of PCM material in PCM, not for PCM converted to DSD?
If I am right about this, then I don't understand the talk of a transformer just at the 1795 outputs. In fact, maybe you can explain better to a layman like myself exactly how your output stage design improves upon what the HAP-Z1ES comes with from the factory.
...The output of the DSD engine is fed directly into the output stage which is based on high speed video amplifiers, passive filtering, including a carefully crafted high bandwidth audio transformer at the output. Unlike conventional DACS that depend on active analog output circuitry and the problems associated with them, DirectStream is purely passive.
Specifically, how would your output design differ in philosophy from this? Or is it even a relevant comparison?
Thanks, Vinnie. Your explanations clear-up a lot for me. But what, then, does the FPGA do?And, yes, I had noticed the same contradiction in the PS Audio quote.
Vinnie, this is the most informative thread about modding Z1ES so far - thanks a lot for it!
I am a bit afraid of tubes since I have zero experience with them but will watch this place closely and who knows
One repeated transformers question, please - are the primary Tx windings easily adjustable inside for 100/120/220V operation or they are custom build for each US/EU/JP version?
Any ideas to design optional output buffer and analog volume control inside the unit so one can easily connect the power amp directly to Z1ES, please?
Okay, all that has been said is all well and good the question remains: what are the advantages of your modded Sony over the PSA model?
Seadogs, Your insistence on this comparison is perplexing. Why are you assuming that the two units have anything in common (except DSD, assuming you are speaking of the new PS Audio Directstream DAC)? They are nowhere in the same category of functionality, position in the system or price point. One is an all-in-one standalone player/server, and one is a new DSD-capable DAC. As has already been enumerated, the player/server has its own storage, it's own GUI interface app, it's own cpu, it's own OS, etc. The PS Audio DAC is a dedicated DAC that requires all the aforementioned pieces to already exist in one's system (plus cabling and power to all)...like any other DAC. The Sony (and modded RWA Sony) is intended for an all-in simplicity...plug and play. And all this functionality wrapped in a package priced 3X less than the PS Audio (maybe 2X once Vinnie is done dunno). Apples vs ashtrays.The PS Audio Directstream DAC (I heard it last week when I spent over 2 hours with CEO Paul McGowan at his PS Audio HQ in Boulder) is to be compared to other $4k+ DSD-capable DACs (there are about 50) to be fair to any reasonable comparison discussion. It would be like asking if a $2K integrated digital dac/amp outperforms a $6k dedicated preamp. Maybe due to synergy, but I doubt it..and in what function can they be compared? only switching and volume control really. The former has amplification and digital inputs, the latter needs a DAC and amps already in place to compete and compare.
And if you wanted an analog input that would also pass into the volume control and tube output stage, I could add a switch for that (so you could hook up an external analog source like a phonostage or iPhone/iPad for streaming Spotify or whatever). Vinnie can you talk a little more about this. I like the idea of having one box and being able to remove the Squeezebox from my setup.
For me, I only care about sound quality. In stock form, Directstream is PROBABLY superior due to it's discrete analog output stage. But after Vinnie's mod, who knows. It's VERY VERY possible HAP-Z1ES will be superior to Directstream. Just the fact PS Audio is more expensive, no guarantee it's superior in performance from my experience in this hobby.
I heard a professional reviewer replaced the internal HDD with a SS HD with excellent results.
Due to it's limited input options, people view HAP-Z1ES as entry level.
IMO, except for pre-loading tracks to the DAC's memory before play, it's probably superior to all external transports feeding the DAC real time.
