0 Members and 1 Guest are viewing this topic. Read 14147 times.
Ouch! Hi Charmerci,This is Alberto, the guy behind The Delicious One. I hope it's OK to post to defend/explain myself (if not, apologies to the moderators and please feel free to delete this post.)I can't disagree with your assessment. The Limited Edition of The Delicious One is expensive because I personally, build, burn-in and test each one by hand and some of the components I use are quite expensive until I can get them in quantity. The solid aluminum knob alone costs me $35 at this time.It's my dream and objective to make it much less expensive; but, as I am working on that I am starting to understand why some seemingly simple audio components (e.g. cables, stands, etc.) can cost so much ... and why so many manufacturers go to China to lower prices. I know this is a lame defense, but some the interconnects I am using cost more than The Delicious One ... I just had to say that .Anyway, fair comment and characterization ... I am myself embarrassed and disappointed that I can't make it cheaper yet, while maintaining the quality. But I am working on it.AlbertoEDIT: Thank you Moderator for allowing me this reply.
They might be more successful in getting more units out for evaluation if they built a simple utilitarian box that does the same thing for less than $100. If someone really likes what it does for their system and wants to go all out, they can upgrade to the "big knob" premium box for the price difference.
What does the toggle switch do?
It looks like a variation on the Yamaha loudness knob which used to be part of most Yamaha receivers. I think the concept is a clever one and very valid for a minimalist set up which has no tone control at all, and often wondered why other receiver designers did not include something similar on their products. My assumption is that either Yamaha had patent protection or the whole idea was a little too confusing for the average user.The procedure with the Yamaha was to turn the loudness knob up full, adjust volume fully to natural (loud) levels, then reduce from that to desired listening levels with the loudness knob which progressively overlays the Fletcher-Munsen type compensation to the signal.This, plus a decent parametric EQ (to compensate for speakers and room) and you're done! Or skip the parametric if you have a great room and speakers.
It's rather funny that this "2nd" comment came up well after some of the other posts. (Due to the fact that AC doesn't post first comments until a period of time has elapsed.Anyway, Alberto something like this may find its niche but my pocketbook is too small for this. Good luck. (I don't think anyone expected you to register and reply!)
