We have refined the design of our ABX component comparator and also made it much more affordable.
It now is direct coupled in to out (no capacitors in the signal path, no active solid state components, just carefully designed pop free relays and instant quiet switching with silicon volume controls for exact level matching.
It allows direct comparisons of two preamplifiers, two power amps, and three set of speaker systems either separately or at the same time. It even allows comparisons of interconnect cables.
Here are the details:
The price is $999
ABX Switch, rev 2, by Audio by Van Alstine 01-26-14
The ABX Switch allows seamless switching of up to two sources, two amps, and three sets of speakers.
Controlled by universal remote, usually from the listening position, the ABX switch has the capability of:
• Precise volume level matching, within 0.1 db, of any selected system.
• Infrared universal remote control.
• Blind test mode (2 of them) can force evaluation strictly by how it sounds.
• Works with or without a subwoofer.
• Programmable power up state and adjustable display brightness.
• Persistent volume settings power up the same as they were when last powered down.
• Multiple systems can be set up permanently and switched in/out instantly with remote control.
• Low noise
• Built in “Y” splitter can be used to drive two units with one source
• Allows selection of up to two speakers at the same time
• Mute entire system with a single button
• Gold plated RCA connectors for line level signal connections
• Gold plated 5-way dual banana connectors for speaker level signal connections
• DC coupled (no capacitors in the signal path).
If you are interested, contact me and I can e-mail you the full operation manual including photos inside and out.
