0 Members and 1 Guest are viewing this topic. Read 16145 times.
In general I don't care much for ATM's...especially when they charge a fee !!! But AMT's I have heard a few, they sounded quite good....but I have not heard them enough to comment on their character of sound.What I can tell you is they are designed to go lower into the midrange better than a pure ribbon tweeter which will run into power and excursion issues. The pleated diaphragm is more efficient at coupling with the air in the mid frequencies , enabling it to blend better with a woofer. But like everything in the world there is a compromise, the diaphragm material and bonded conductor is thicker than a ribbon which will not have the same top end response as a ribbon. This is not necessarily a bad thing...just something to consider in your design process. The Ess Heil unit is quite pricey...the Dayton unit is less than half the price and seems to have more radiating area http://www.parts-express.com/dayton-audio-amtpro-4-air-motion-transformer-tweeter-4-ohm--275-094. These units also seem to like at least 2nd order networks..something I don't. The Dayton unit boasts a diaphragm thickness of .0005, I don't know if this includes the conductor traces or not...this is not thin. You would think it could handle a 1st order network. The ribbon tweeter I build, which is aluminum foil bonded to mylar is much thinner and I have no problem crossing it over with a 1st order network. Greg
Rainier
This's mine
Greg, I have seen these (amt) used with other tweeters, using the amt, kind of like a midrange driver. Can your ribbon tweeter be set up with two woofers ?
Anyone ever listen to one ? Or know anything good or bad about ATM's in general ?I was pondering the use of one in an OB speaker. (WOOFER/ATM/WOOFER or WOOFER/MID/ATM) http://www.parts-express.com/ess-heil-air-motion-transformer-amt-tweeter--264-600
I think John (InfernoSTi) has the Rainier and he's not too far from you Jim.And you can ventured to Dallas, dinner is on me.
Brad, Are you using it in a two way or three way application ?Couldn't a pair of woofers be used with it ?
Thanks for the links on the other drivers. They were a bit out of my price category during initial concept time, but either that Aurum or the Beyma would provide an upgrade path for me
