626 refurb.
0 Members and 1 Guest are viewing this topic. Read 844 times.
soarertoy
626 refurb.
« on: 11 Jan 2014, 06:28 pm »
Hi,
I'd like to change the cloth on the front covers of my 626's, has anyone any tips on this?
The cloth appears to be secured in a slot on the rear of the frame, how is it released?
Is there a particular supplier for the "clips" that hold the cover onto the speaker? I have just bought a 626 with all the clips broken.  :duh:
Richard
chipperman
Re: 626 refurb.
« Reply #1 on: 11 Jan 2014, 06:36 pm »
If your clips are the ball and socket type they have them at Parts Express. Not sure what type of grille cloth you have. Does it cover the whole front of the speaker?
Doublej
Re: 626 refurb.
« Reply #2 on: 11 Jan 2014, 09:32 pm »
Consider putting some pictures of the grill in your gallery so folks can have a better understanding of your situation.
Brax
Re: 626 refurb.
« Reply #3 on: 12 Jan 2014, 12:57 am »
Since the clips are broken, you may want to just replace them with magnets. Take out the broken clips and glue in the magnets on both the speaker and grill.I did this to my LRC. I like them better and they won't break off.
