Hooking up a hard drive to the Modwright Oppo BDP-105
0 Members and 1 Guest are viewing this topic. Read 2959 times.
ajayrav
I've got a Western digital My Passport hard drive hooked up to my Modwright Oppo BDP-105.  It is connected by a generic USB cable, which I believe is fine, since I am not connecting to the USB DAC.  Is that true, or would upgrading the USB cable make any difference in this case?
Ajay
Austin08
Re: Hooking up a hard drive to the Modwright Oppo BDP-105
« Reply #1 on: 11 Jan 2014, 04:55 pm »
Oppo 105 is your usb dac.
ajayrav
« Reply #2 on: 11 Jan 2014, 05:01 pm »
I thought in my case I was bypassing the asynchronous USB in, as opposed to connecting my computer USB out to the Oppo.  Is that not correct?
Ajay
Austin08
« Reply #3 on: 11 Jan 2014, 05:05 pm »
If you use Oppo's analog out then you use its dac. It does not mater the source is from discs, hdd or network.
ajayrav
« Reply #4 on: 11 Jan 2014, 05:08 pm »
So you are saying that the USB cable will make a difference then, right?
Ajay
Austin08
« Reply #5 on: 11 Jan 2014, 05:16 pm »
You have an excellent Oppo Modwright 105 then why not using its DAC via Asyn usb (the best connection on this player) It is up to you to try a "better" usb cable. I am using Silnote Poisedon silver statement usb cable and very happy with the result.
Ern Dog
« Reply #6 on: 11 Jan 2014, 06:07 pm »
Ajay
You bet it will. Get a nice one.
