Audio/Video Gear and Systems
Owner's Circles
VMPS Speakers
RSorak
WTB: Pair of VMPS 626's
0 Members and 1 Guest are viewing this topic. Read 3828 times.
Hemy
26 Nov 2013, 04:20 pm »
Anyone have a pair of 626 speaker's similar like the ones in this setup?
http://www.audiocircle.com/index.php?topic=117322.0
I am buying the outside pair from Doug but need one more set to complete my all VMPS 7.1 surround sound (future) Home Theater.
Last Edit: 9 Dec 2013, 04:10 pm by Hemy
Hemy
Re: WTB: Pair of VMPS 626's
7 Feb 2014, 03:05 pm »
I am still looking for a pair like these if anyone knows of someone wanting to sell theirs.
fredgarvin
Reply #2 on:
7 Feb 2014, 06:22 pm »
I have a pair with the older black fronts and the original spiral ribbon tweeters. I doubt the oak finish would match either.
Hemy
Reply #3 on:
7 Feb 2014, 06:48 pm »
Any pictures you could provide? It might work, but I am curious how the different tweeters would sound and work together as I want these to be my surrounds and I already have a pair with the other tweeters.
Stimpy
Reply #4 on:
7 Feb 2014, 10:19 pm »
For surround use, I wouldn't sweat the tweeter differences. I presume the 2 different pairs of 626's won't be used side by side; most likely a side pair and a rear pair? If so, the different positioning of the 2 sets of speakers will probably have a bigger impact on tonal qualities, than the different tweeters. The spiral ribbon tweeter may have a bit broader dispersion pattern, so maybe use that set for the sides, and use the other pair for the rears? But, who am I to complain; 626's of any type would make me happy, 2-channel or surround!
Last Edit: 12 May 2014, 02:10 pm by Stimpy
fredgarvin
Reply #5 on:
8 Feb 2014, 05:28 pm »
No pics, they look like the one in the center of the photo you linked. I think the crossover point is different in the two tweeters, I'm not sure how that would match up.
Hemy
Reply #6 on:
11 Feb 2014, 01:25 pm »
Thanks Stimpy. That might allow me to go with that pair for cheaper since they are older. Unless I can get the others for the same price.
Hemy
Reply #7 on:
14 Feb 2014, 02:10 pm »
How much for yours Fredgarvin?
Hemy
Reply #8 on:
18 Mar 2014, 01:29 pm »
Stimpy
Reply #9 on:
18 Mar 2014, 04:23 pm »
You might want to send a direct PM, or a direct email. Not a huge amount of new info or traffic here, now, so no way of knowing when fredgarvin might visit again, and see your request.
Quote from: Hemy on 18 Mar 2014, 01:29 pm
Hemy
Reply #10 on:
7 May 2014, 06:04 pm »
Anyone else with some 626's or surrounds, hopefully in oak, they want to sell?
Hemy
Reply #11 on:
11 Jun 2014, 07:23 pm »
Still looking if anyone knows....
ZAKski288
Reply #12 on:
11 Jun 2014, 10:00 pm »
Theres a pair of Light Oak RM1 for sale.
Hemy
Reply #13 on:
12 Jun 2014, 11:20 am »
To big, looking to use the 626's as surround speakers.
HAL
Industry Contributor
Reply #14 on:
12 Jun 2014, 02:34 pm »
I have a pair of QSO626R's in light oak that look like the ones in the main positions of the picture.
They are kits, and setup for external crossovers and triamp setup. The rear panel was replaced with a new one with three sets of 5 way binding posts wired to each driver. It is glued in place.
I installed Aurum Cantus G2 ribbons to replace the originals when the ribbons stretched. I have put new ribbons in the FST's but could never get it tensioned properly. I have new Sonigistix panels to go it them, but not installed. Just needs to be wired to the connectors.
Have the parts for the original standard passive XO to use with them, they just have to be wired up and put in an exterior box like Brian's speaker box stand idea.
I have the original boxes, just not sure how well they have survived but can look.
This is a project, not completed speakers. I used them with the GR-Research passive XO redesign and a DCX2496 and those worked well. I am keeping the GR-Research XO's and the DCX2496 for other projects. The passive parts came from other speaker XO's I have to install.
If this is something of interest, PM me and I will add pictures if interested.
Hemy
Reply #15 on:
12 Jun 2014, 04:05 pm »
Pleas add as many pictures as you can as I can't quite picture them. I only need a pair of them.
HAL
Reply #16 on:
12 Jun 2014, 05:31 pm »
Here is the picture with the original drivers installed when I first built them.
Hemy
Reply #17 on:
12 Jun 2014, 07:12 pm »
Those look pretty nice HAL. Can you show me the back of them and what I might need to run them? Are they single / bi or tri amped each?
Hemy
Reply #18 on:
12 Jun 2014, 07:14 pm »
So re reading your post, do you have all the parts to make it a "standard" 626 where the XO is on the inside?
HAL
Reply #19 on:
12 Jun 2014, 08:41 pm »
The box is moded to have the XO external. I have all the original parts, but they have to be outside. I sealed the L-Pad control holes so the driver loading was correct.
Owner's Circles
VMPS Speakers
RSorak
