Hi
i
SOLD Class D Audio SDS 254 amplifier .
amp is fully assembled in a nice chassis in good condition , with rca and xlr input options , only the rca's are connected at this time . 250w into 4 ohm , 125w into 8 ohms,
here is a chance to get a great class d amp assembled for less then the parts cost .
asking $350 plus shipping
paypal adds fees
i will add pictures in the next few days.
here is some more information on the specs for this amp:
http://classdaudio.com/amplifier-kits/sds-254-kit.htmlSDS-254 Class D Audio Kit with Large Power Supply, AnTek 400VA Transformer, Molex Connectors for external LED's, power switch, and gain controls. High Quality Conductive Plastic Element External Gain Controls also included. Our new Super D Series audio power amplifiers are built on the highly acclaimed reputation of our CDA series amps. Our goal was to keep the excellent sonic qualities while adding a state-of -the art balanced input stage (also accepts standard single ended input) and external adjustable gain controls. We've also added a better cooling system, Molex connectors for external LED's, power switch, and gain controls (included). The balanced input stage is one of the finest available and normally only found on very expensive high-end equipment. When using single ended inputs, you can change a jumper to select inverted or non-inverted input as well... useful in some instances. The gain controls included with this kit feature a conductive plastic element for ultra low noise. Our Super D Series amps provide more life-like imaging and sound stage, along with the beautiful smooth tube-like sound we're known for. These amps are powerful, clean, quiet , and transparent. Specifications: · Output: 250 X 2 - 4 Ohm, 125 X 2 - 8 Ohm · Bridged Output: 500W X 1 - Bridged 8 Ohm (Full Bridge) · THD+N, 1W - 1KHz: Better than .02% · Dynamic Range: 101 db · Efficiency: Over 90% · Required Power Supply: +/- 40 Volts
