Custom Internal Wiring for Omega Speakers
0 Members and 1 Guest are viewing this topic. Read 4659 times.
beowulf
« on: 7 Nov 2013, 02:38 am »
Obviously Omega's uses excellent materials all around and I'm very happy with my speakers, and honestly I'm not even sure what type of wiring the Omega's have in them at all ... but I was just curious if anybody has ever ordered a pair (or re-wired their own) speakers with custom wiring, etc. and what their thoughts were?
Custom cable guys (such as our own AudioCircle member DaveC) are using cutting edge cabling such as OCC copper, silver and other exotic metallurgy and are getting excellent results with their external cable designs and I'm interested to know how Omega Speakers would sound taking it a step further going internal with some of the same cutting edge cabling like DaveC and others are using?
I know that you can custom order Zu Audio speakers where the internal speaker cable comes right out of your speakers into your amplifier and bypass the speaker binding posts altogether.  It seems like this could be very cool if you are using ~ say some really high end wire such as OCC Copper or 4 9s silver internally from the speaker straight to the amp and eliminating one less connection altogether.
What do you guys think?
  • All Tweeters look like a target, then shoot them!
Re: Custom Internal Wiring for Omega Speakers
« Reply #1 on: 7 Nov 2013, 08:43 pm »
Frankly, I hate internal wiring and connectors.
As Omega use a sole fullrange driver, the speaker cable must be solded in the drivers pegs/bayonet connectors.
This system offers fewer connections, solder joints or contact pressure.
The internal wiring being a different wire from the speaker cable is not a good thing.
Changing the wire, the electric signal change all its propagation behavior;
Brad
« Reply #2 on: 7 Nov 2013, 09:08 pm »
I think Louis is using a nice cotton-insulated solid core copper (by Jupiter), for the internal wiring on his speakers.
beowulf
« Reply #3 on: 7 Nov 2013, 09:19 pm »
The internal wiring being a different wire from the speaker cable is not a good thing, changing the wire the electric signal change all its propagation behavior;
So would I be right in thinking that speakers would sound better with the same wire from the driver all the way to the amp (without any connectors at all)?  If so, I wonder why more speaker manufacturers don't have this as an option?  Excuse the dumb question ... but is there any reason (safety, protection, etc.) why you would need to add binding posts to a speaker at all ~ other than for people to choose their own external cabling?
The more I think about it, the more it seems like it could be a better design as long as the cabling was high quality.  Without the extra stops (a la terminations) during the current flow and using all the same cable it just seems like a better path.
I have always wondered what could be better than the actual internal wiring of the speaker itself?  We use all kinds of expensive and exotic cables that go from the amp to the speaker's binding posts, but internally the speaker's driver is most likely wired differently ... how much of an improvement could really be taking place if the speaker wire is not the same quality and/or mettallurgy of the internal speaker wiring?  Wouldn't the "true" sound of the speaker be dependent on the cabling that is actually installed on the driver itself and not on the external cables because once it hits the binding post the signal is handed over to the internal wiring?   (and I'm not speaking towards Omega directly, but torwards any manufacturer in general)?
I recently read a paper from Tempo Electric called Wire and Cable Facts and it said that bare wires are the best termination, followed by spades and lastly bananas ... so imagine if we had wire from the driver into the amp without any terminations at all ... the paper then goes on to say that the worst terminations were the ones with different materials (i.e. copper spades to silver cables, etc.), so in that case it should (?) apply towards the speakers as well no? (i.e. silver external cables to copper internal cables, etc.)
« Reply #4 on: 7 Nov 2013, 09:39 pm »
I think internal wiring and connectors as cheap spice.
They are there just for convenience.
DaveC113
  • ZenWaveAudio.com
« Reply #5 on: 8 Nov 2013, 04:12 am »
Yes, the connectors are for convenience. Good ones aren't a big sonic penalty but are expensive. Keep in mind everything you do alters the sound so you need to decide for yourself how far you want to take it.
People need different length cables so having a speaker with a captive speaker cable wouldn't work for everyone and the best cable to use might also depend on what amp you're using as well as the personal preferences of the listener.
Good wire and connectors are important, I believe Louis uses Jupiter Condenser's wire which is very good stuff. IMO the worthwhile upgrade is the binding posts... I like Furutech connectors in general but have not had a chance to use their binding posts. There's also the Pomona 3770 gold plated copper binding post for $9/ea, I used them in my system... they look like super cheap stuff you'd get at Radio Shack though.
« Reply #6 on: 8 Nov 2013, 10:44 am »
Yes, I finally tore out the binding posts to my single driver speakers a couple of years back and ran my cable of choice directly from mono blocks to the drivers.  Can't really say it sounds better, but its one of those compulsive audio purist things that helps me sleep at night knowing I've eliminated two connectors, cheap internal wiring, and the binding post from the signal path to each channel.
rollo
  • Rollo Audio Where Home demo rules
« Reply #7 on: 8 Nov 2013, 02:27 pm »
  Well they will sound different. maybe better maybe not. One would imagine without any connectors a pure transfer of signal. But, but the designer voiced the speaker with the binding posts and internal wire. So the difference.
   For me no connectors at speaker terminals bare wire for mains a jumper. An improvement in imaging and soundstaging. Tonality the same except for top end which is more open and present.
   Only way to tell is to try, have fun.
charles
DaveBSC
« Reply #8 on: 8 Nov 2013, 02:30 pm »
Provided the binding posts are made mostly out of a high quality, high conductivity metal as opposed to the mostly brass ones that sell for a few bucks, the damage they cause should be fairly minimal, and for most people being able to change cables or use whatever cable length they may require is worth the small sacrifice in sound. Using the same speaker cable both externally and internally I think will provide better results than eliminating binding posts, or at the very least using same metal cables, ie if Omegas are wired internally with solid core copper, use solid core copper speaker cables. Whatever you do, don't use silver plated copper anything.
In spite of what Nordost and other companies that sell plated cables may tell you, plating one metal over another for cables that operate in the audio band (rather than S/Pdif cables, USB cables, and other UHF types) is pretty much the worst thing you can do, sound wise.
beowulf
« Reply #9 on: 8 Nov 2013, 08:55 pm »
I would have to agree with your assessment about the different materials as it falls along the same lines as the report of the link I posted above.  Silver speaker cables to brass/gold plated binding posts and then copper internal wire seems like it would not be optimum.  Anyways, how much of the silver would you really hear once the signal is passed into the copper cable?  I do believe that the conductivity of silver may transfer the signal better to that point, however isn't that like driving a Ferrari up to the front gate and parking outside, then driving a ford all the way home?
charles
Charles you bring up a good point too, since they were voiced with binding posts if someone were to put all silver cabling internally and externally without using binding posts they would most likely sound quite different.
beowulf
« Reply #10 on: 8 Nov 2013, 09:03 pm »
Would you say that the gauge of wire you would use has to be changed at all from the original specs?  For instance Jupiter Condenser's highest gauge copper is about 18 ... would there be any harm in using say 10-12 gauge instead? (ie directly to the driver out to the amp)
« Reply #11 on: 9 Nov 2013, 02:20 pm »
With single driver designs (and realizing that the cabinet can only really affect frequencies below roughly 300 Hz), the voicing should be purely based on the raw driver that (I got to believe for convenience sake) was done with a straight run of cable from the amp.  But what cable?  And more importantly what amp?  And most importantly does the voicing preferences of the driver designer match my preferences?
DaveC113
  • ZenWaveAudio.com
« Reply #12 on: 9 Nov 2013, 03:41 pm »
I'd just add that there's no issue with using different speaker cables than what the speaker was wired with internally, it almost NEVER matches IRL anyway.
Everything makes a difference but at some point it doesn't make sense to worry about it, that point is up to the individual...
Good Times
« Reply #13 on: 10 Nov 2013, 10:08 am »
I would never go to the extent of specifying a run from driver to the amp. If you damage your cable or termination, then you're stuck.
On the HB range I recall Louis used to apply a dual run on the +ve, single on the -ve (correct me if I'm wrong). I agree with the above advice though on keeping metal changes to a minimum, so would be using gold-plated termination and multi-stranded copper wire only.
« Reply #14 on: 11 Nov 2013, 05:00 pm »
Not sure if I understant it right. Anyway I use inexpensive QED Silver Anniversary, a 2,5mm Silver/copper with a 5inches FR, but I would double/triple it as I have a spare run, but my pro-audio FR are not great.
Some speakers cables are small awg as Cristal Cable others are big as pipe.
Hi-fi FR drivers are not intend to be used with capacitors, condensers, inductors etc, unless in pro-audio drivers.
These Omega FRs are the most light weight cones I have see, even more light than the Alpair12P, so a capacitor or condenser will do a huge effect on the sound.
One can change some sound attributes as treble by changing the speaker cable.
Some small tube amps need to fell a higher impedance than 8 or 16 ohms, so it is used a sole solid core thin gauge wire as friendly passive way to get it.
DaveC113
  • ZenWaveAudio.com
« Reply #15 on: 11 Nov 2013, 06:59 pm »
I've heard of people doing that, but it's a really bad idea and will have a very negative effect on dynamics. You want as much impedance as possible to come from the driver's motor where it actually does something.
opnly bafld
« Reply #16 on: 11 Nov 2013, 09:16 pm »
Jupiter Condenser is the name of the company, he is talking about their wire.
http://jupitercondenser.com/Cable/cotton-insulated-cable.html
Lin
« Reply #17 on: 12 Nov 2013, 12:14 pm »
Lin
Thanks for clarify :thumb: you most kind.
These are very nice wire, but the thicker seems to be 19awg, a bit thin to speaker cable or even small tubes apply.
IMO: I afraid it may becomes too hot in afew hours of continuous use, also it is not solid but stranded from a thinner wire.
I would not use this wires in my loudspeaders or tube amp as they are too thin, otherwise seems good.
« Last Edit: 12 Nov 2013, 02:43 pm by FULLRANGEMAN »
DaveC113
  • ZenWaveAudio.com
« Reply #18 on: 12 Nov 2013, 03:48 pm »
FRM, in your last post you talked about using super thin wire to increase resistance in tube amps, calling that "friendly", but now 19g isn't big enough for speaker cable?
FWIW, I use and sell 20g speaker cable and I believe Louis is using 20g internally. 20 gauge is a great size wire for small amps and efficient speakers.
Also, I remember Dave at Planet10 saying he used a single twisted pair of cat5, which is 24g... less than half the size of 20g. Personally, I do think that's getting a bit on the small side, but it's still not going to heat up, lol...
« Reply #19 on: 13 Nov 2013, 09:54 am »
Seems these gauges you mention will offer a more friendly impedance to the amp, but I could not use it myself.
I understand the option of these manufacturers as a thinner wire have less resistence and less cost.
