0 Members and 2 Guests are viewing this topic. Read 5540 times.
So unfortunately the tool doesn't work properly on at least two PS3 models (CECHG, CECHM). It's a question if it works at all on any non-SACD consoles. I'll report this problem to the author of the tool, Glevand. Unfortunately I'm not in his inner circle of PS3 hackers so not sure that I'll get a response.
Can you let us know the console's that it seems to work on
HiI have two of these CECHM models, both I have bought brand new from shop and they have never been in any repair. Is there any way I could check what the logic boards are?
Hi, I am reading this with great interest. One thing I would really like is reliability and I am afraid that given the age of these units that once I have everything working, any one component is the PS3 will die and render the whole thing inoperative. I'm not technically inclines, but after reading numerous posts, it appears that the drive we need to read SACD's is BMD-001 due to a special chip on this drive. Is it possible to remove this drive and attach it to a PC and then this way, we can avoid the FW3.55 issue as well? I assume the programming part is also easier on an "open" system? If the drive has a sata or IDE interface, then it should be easy?Does this make any technical sense?
