Who would have guessed...
0 Members and 1 Guest are viewing this topic. Read 1892 times.
/mp
« on: 10 Oct 2013, 08:38 pm »
an Rm9 mk.II outputs 250 watts per channel into 4 ohms?
https://app.audiogon.com/listings/tube-music-reference-rm-9-mk-2-250wpc-tube-amplifier-2013-10-10-amplifiers-33326-davie-fl
I wonder what the distortion level is at that power level?  ;)
rbwalt
Re: Who would have guessed...
« Reply #1 on: 10 Oct 2013, 09:25 pm »
don't think the tubes are going to last very long.
here are the specs for the RM9 MKII
8 ohms:
power 128 watts
dissipation 100 watts
4 ohms:
power 65 watts
dissipation 156 watts
2 ohms:
power 40 watts
dissipation 200 watts
now for the RM9SE:
8 ohms:
power 162 watts
dissipation 88 watts
4 ohms:
power 200 watts
dissipation 95 watts
2 ohms:
power 128 watts
dissipation 110 watts
as a side note: as good as the RM9mkII  is the RM9SE eats it for breakfast. i know i have had both and still have the SE.
pehare
« Reply #2 on: 10 Oct 2013, 11:15 pm »
looks like a nice amp :thumb:
Ericus Rex
« Reply #3 on: 11 Oct 2013, 12:20 am »
..."when strapped for mono with a second sample."  He's talking about using 2 RM9s as mono blocks though the ad is only for 1 amp.  Sneaky and misrepresentative, IMO.
rbwalt
« Reply #4 on: 11 Oct 2013, 02:20 pm »
i had a sneaky idea that it was strapped. thanks for pointing that out. buyer beware.
Roger A. Modjeski
« Reply #5 on: 22 Oct 2013, 09:44 pm »
Strapped into mono the RM9 mk II will put out 250 watts into a 4 ohm load off the 8 ohm tap. The SE version will put out more as rbwalt notes.
