Thank You Roger!
0 Members and 1 Guest are viewing this topic. Read 990 times.
mrdrumbeat
Thank You Roger!
« on: 7 Oct 2013, 11:59 pm »
Thank you Roger for putting things into perspective for me.
This all started because I bought my first MC cartridge w/o out doing all my homework.
I would not have been this confused if I just stayed w/ MM cartridges but live and learn.
Anyway, my take away from you is before I go and buy an RM4:
A.  Once I get the MC cartridge I'll play the system as is first
B.  I'll see if I need to step up the gain
C.  If after that it all sounds good, I'll do nothing but enjoy
D.  If there is noise that I don't like and/or I do not get enough gain to make the cartridge sound sweet I will
give you a holler and try the next step you suggest.
Thanks for the common sense!
My tempo is in the pocket for now!
Mr. Drumbeat
