LDRxB.V25 Balanced Passive Preamps
0 Members and 1 Guest are viewing this topic. Read 49362 times.
tortugaranger
    • Tortuga Audio
Re: LDRx Unbalanced & LDRxB Balanced Passive Preamps
« Reply #80 on: 31 Mar 2016, 02:37 pm »
Thanks Morten. Interesting, and yes, such a feature could be quite useful. Do you have a rough ETA on its availability, if ever? I understand it requires some complicated work, and I do wonder if enough customers might want such a feature to make it worth rolling out. Anyway, thanks.
Can not give any estimates on timing or even if this will become a feature. Too early to say.
Pale Rider
« Reply #81 on: 31 Mar 2016, 03:00 pm »
Understood. Thanks.
tortugaranger
    • Tortuga Audio
« Reply #82 on: 12 Jul 2017, 02:05 pm »
Added a couple of updated pics of the LDRxB Balanced Passive Preamp rear panel.
The original rear panel had the option of using Cardas XLR jacks. These proved to be a huge disappointment. Not in terms of sonics but in terms of mechanical reliability. They would literally fall apart, often during shipment so we stopped even offering Cardas XLR jacks. We now use Neutriks exclusively for balanced I/O and they are all around excellent XLR jacks.
tortugaranger
    • Tortuga Audio
Re: LDRxB.V25 Balanced Passive Preamps
« Reply #83 on: 2 Nov 2018, 08:19 pm »
Pics of the newly updated LDRxB.V25 Balanced Passive Preamp. More info here: https://www.tortugaaudio.com/products/passive-preamps/ldrxb-v25-balanced-passive-preamp/   :thumb:
« Reply #84 on: 2 Nov 2018, 09:12 pm »
So it doesn't look like the RCA's are transformer coupled like you had done in the past. So when you select the RCA (input 4) you are only sending the signal to one of the preamp boards and getting the unbalanced output from the same board?
kernelbob
« Reply #85 on: 2 Nov 2018, 11:59 pm »
Hi all,
Though the comments regarding absolute phase/polarity inversion are not recent, I wanted to post a long term update on my experience with the option.  I've used the Tortuga LDRxB with the phase inversion option now for a couple of years and have auditioned it in various systems.
The degree of difference between "normal" versus "inverted" is much influenced by the quality of the bass drivers in your speakers and the control provided by your amplification.  With more rigid, fast, controlled drivers there is more difference between the normal/inverted setting than with drivers that exhibit a higher amount of flexing.  Similarly, using an amplifier that does not adequately control the drivers, there is less difference.  However, with well controlled, fast drivers with a higher Young's modulus (ratio of stiffness to weight), the correct setting is obvious.  Regarding the terms "normal" and "inverted", these are relative to your system's configuration.  Each gain stage inverts phase.  Whether you attach the red speaker cable to one terminal or the other inverts phase, etc..
Once you've lived with the Tortuga LDRxB with the phase inversion option, you'll find that you can tell if a recording is correct or needs to be inverted relative to your system's acoustic polarity without even having to test the normal/inverted setting.
A key feature with the Tortuga is that you can switch between phase settings with the remote from your listening position.  The other great feature is that you can at the same time select (also from the remote) between the various input impedance settings that best suit your system and the recording.  In my system, just changing from one impedance setting to another only 3k higher or lower modifies the flavor of the sound and I frequently switch to the setting that gets the most balanced, natural sound from a recording whether it was recorded last year of half a century ago.
The Tortuga is an exceedingly transparent and revealing tool.  Not having any gain stages, capacitors,switches, or potentiometers is something to hear.  The features of absolute phase control and custom input impedance settings (all from the remote) are features I would now not be without.  Add that it is a bargain compared to the sonic competition.
Best,
Robert
tortugaranger
    • Tortuga Audio
« Reply #86 on: 3 Nov 2018, 07:48 pm »
Correct. In hindsight the sonic drawbacks of converting/splitting an unbalanced signal into a balanced signal using a transformer just so you could have it also appear as a balanced output were not worth it. Better to have a better sounding single ended signal handled as a single-ended signal while also making it available on one phase of the balanced  output albeit at a slightly lower energy level.
