0 Members and 1 Guest are viewing this topic. Read 39213 times.
I've tried both. The Mullard Reissue EL34s I thought they were nothing special. They only lasted about 1000 hours before they started dying. One developed bad grid leakage and the others tested very low. They should have lasted 3000 hours +. The JJs I thought sounded a bit worse than the Mullard reissues. Equally dismal fail rate. These comparisons were probably 8 or so years ago. Maybe both companies have improved reliability.The best sounding affordable tube I've tried is the RFT/Siemens EL34. You can find them for $100/quad sometimes on ebay and around $50 each from more reputable dealers. These sound just about as good as NOS Mullards at a fraction of the cost.
New Sensor is the maker of the Mullard reissue using the original tooling from England. Many people do like them.
Original Mullard tooling? These tubes are supposed to be an attempt to clone the Mullard XF2 design, but I haven't seen anything stating that New Sensor has any of Mullard's EL34 tooling. If true then this would certainly be an item of interest to many.
Apologies as I think I got that from this forum.http://www.gearslutz.com/board/low-end-theory/469913-reissue-russian-mullards.htmlAs with any forum, the information gathered should be corroborated through trusted sources. My bad.
I prefer the JJ KT77 vs. the two tubes under consideration.
Have you had a chance to try the Gold Lion reissue KT77 ? If so, how do they compare with the JJ's ? I hear so much about the poor QC and relieablitly issues with the JJ's... makes me a bit leary. Some vendors say the issues have been dealt with long ago , then there are others who say they still wouldn't touch them. How's your experience been ? -jay
