0 Members and 1 Guest are viewing this topic. Read 16791 times.
Ed,Brian's idea on beards and no spikes was based on the propagation of the 360 degree pressures of bass waves.They travel in a 360 spherical radiation, contained only by solid boundaries.as the bass wave leaves the slot, it then radiates in that pattern. it will travel down the solid surface of the slot to the solid boundary of the floor.The break in the boundary between the bottom of the slot and the floor allows some of that pressure to go into that opening, and "in theory" would slightly reduce the pressure that would come to you.I say "in theory" because I tend to think that you wouldn't notice too much difference, or that the advantages of mobility might outweigh them.
