Is Bryston 3BST is true balance designed ?
0 Members and 1 Guest are viewing this topic. Read 2145 times.
oris98
« on: 21 Jul 2004, 08:18 pm »
Hi all,
I am in the market of getting a preamp.  Someone suggested me to go for the one which has a balanced to make use of the Bryston's balance input if the bryston true balanced design.   Do you guys know if Bryston is true balanced ?  If not why it has a balanced port at the back ?
Also, if the Bryston is true balanced, would it be affecting the sound quality if I do biamping setup with a second amp which has no balanced input ?  My concern is one amp is balanced and the other amp is single ended RCA, it may cause any tonal mismatch ?
Many thanks in advance..
Yogus
« Reply #1 on: 21 Jul 2004, 09:33 pm »
Check out http://www.audiocircle.com/index.php?topic=10038.
There should also be some info on http://www.bryston.ca/newsletters/83_files/vol8is3.html
In short, the 3bst is not a truly balanced amp.
jethro
Re: Is Bryston 3BST is true balance designed ?
« Reply #2 on: 22 Jul 2004, 12:58 am »
Quote from: oris98
Hi all,
The amp connected with a balanced interconnect may have a lower noise floor and will have an extra 6dB of gain but shouldn't sound tonally different (unless different amp models are used).
eico1
« Reply #3 on: 22 Jul 2004, 08:40 am »
A balanced interface benefits in reducing ground loops and ground interaction between components. If the ground currents are modulated by the music the tonality is basically affected.
It is common to use a single ended driver and a balanced input stage as you still get some common mode rejection and this ground isolation.
I don't know where the desire for true balance comes from, as the Bryston piece linked above refers too. I don't know if there is a commercial product that meets those requirements or why you would want one.
steve
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 23 Jul 2004, 11:37 pm »
Yes all Brystron balanced circuits are true differencial balanced circuits.
james
