hi-res dac chipset
0 Members and 1 Guest are viewing this topic. Read 924 times.
marvda1
  • freelance reviewer: The Sound Advocate
hi-res dac chipset
« on: 10 Jul 2013, 03:45 am »
anyone know any thing about this dac chipset? Texas Instruments PCM1796 24 bit/192 kHz. how it sounds. how it compares to other chipsets?
jcotner
Re: hi-res dac chipset
« Reply #1 on: 10 Jul 2013, 05:15 am »
Well you could do a survey of units using these parts.
Here is one I know of:
http://www.spearitsound.com/product.cgi?group=116&product=3024
There are reviews of this box around on the web.
It is an older part that was released around 2006 I think.
TI updated it with the 1795 which is a 32 bit part 192KHz
that is pin compatible with 1796.
The chips support DSD but actual box implementation may
not.
You looking for a plug and play DAC or wanting to build with
this part?
marvda1
jcotner
« Reply #3 on: 10 Jul 2013, 06:22 pm »
OK basically the same thing I posted. Same company builds both.
Likely both use the same DAC circuitry.
Their DAC didn't review that badly.
I don't know what the warranty situation it though because these
folks no longer distribute this equipment.
I think the rep is in Canda now.
Was looking at the DAC pretty seriously until I found out I
had to spend some bucks to get the performance I really wanted.
Both the YBA SACD Player and standalone DAC are older designs,
which I'm sure is the reason they are now cheaper.
