0 Members and 1 Guest are viewing this topic. Read 24333 times.
To be more specific, an ordinary transformer has separate primary (input) and secondary (output) windings, while an autoformer shares some part of the winding between the two.
No comparison if you wan the ultimate in transparency & neutrality. Bent TAP-X!!!
Is your Bent autoformer balanced or unbalanced?
Do you guys ever think about how strange it is that some members make and own stuff like the Bent item discussed here, that perform better than stuff priced up to ten thousand dollars in stores?
Jason,Is your Bent autoformer balanced or unbalanced? What is length of your IC, autoformer to NC400? Cable type? Anand,What is length of your balanced IC, autoformer to power amps (NC400 IIRC)? Cable type?
Do you guys run stock DCX2496 high pass to main speakers?
Ok, I have a question.Do any of you guy's run a phono stage like the Vista Audio phono preamp into your TAP-X, or are you running a CD/DAC setup only thru your Tap-X?
I still have the older deep case which I use to park an extra SUV in
