Pre-Gain
0 Members and 1 Guest are viewing this topic. Read 1211 times.
Jos
Pre-Gain
« on: 9 Jun 2013, 03:30 pm »
Hi guys,
I can buy a nice tube pre to go with my 451. I'm just not sure whether the combination is right, since the tube pre has 23 db of gain. As a source I use a phono pre that has an output of 0.8V with my cart. I would't want to overload the m451.
Any thoughts on this one?
Jos
ps. speakers are 95 dB.
« Last Edit: 9 Jun 2013, 05:44 pm by Jos »
Jos
Re: Pre-Gain
« Reply #1 on: 9 Jun 2013, 04:13 pm »
By the way, anybody any idea how much gain the M451 has?
Jos
Jason T
  • Enjoying the music
    • custom cables
Re: Pre-Gain
« Reply #2 on: 9 Jun 2013, 08:49 pm »
jos
the preamp stage of the sensation is passive with no amplification.
the preamp outs are 1:1 using op amps and are seperated from the tripath input section.
I cant see you overloading the sensation
Jos
Re: Pre-Gain
« Reply #3 on: 9 Jun 2013, 09:40 pm »
Hi Jason,
Thanks. But still, why do they make pre-amps with that much gain? I suppose I would hardly be able to use the volume control with 24 dB, or am I wrong?
Jos
Jason T
    • custom cables
Re: Pre-Gain
« Reply #4 on: 9 Jun 2013, 10:05 pm »
I've used my Classe CP-35 as a preamp with my sensation and Two.2 with no issues so I figured I'd check into its gain.
it looks like the phono pre in it makes 42db and the line level gain is 18db
I think you'll be fine at 23db, I cant get my volume to 50% on the preamp using my Classy twenty five, VSP labs trans mos or Sensation so I dont think you have anything to worry about.
I dont know why they make such high gain preamps, my passive pre does just fine
