Audio/Video Gear and Systems
Owner's Circles
Channel Islands Audio Owners
CIAudio
d200 mk2 with PS Audio PWD?
0 Members and 1 Guest are viewing this topic. Read 2318 times.
spreadspectrum
16 May 2013, 08:32 pm »
I am looking to replace the power amplifier in my main system, and have had my eye set keenly on the D200 mk2's.
While I have no real reservations in their performance with either my Thiel CS2.4's or the mark 2 version of PS Audio's DAC, I thought I'd inquire as to the experience of readers here, particularly with the DAC. Information is generally free, after all... I plan in running the amps directly from the DAC.
Looking forward experiencing CIAudio products for the first time. Thanks in advance.
CIAudio
Facilitator
Re: d200 mk2 with PS Audio PWD?
16 May 2013, 09:32 pm »
Hi Spread,
Welcome to the forum!
I don't have any experience with the PWD, but maybe others can chime in.
The D-200 MKII's should work great with the Thiels.
-Dusty
spreadspectrum
Reply #2 on:
17 May 2013, 12:02 am »
Very gracious of you to reply, Dusty.
Indeed, it seems that your amplifiers and the Thiels would make a superb combination. As I said, based on my experience with the PWD, I don't expect anything but goodness there either. Certainly compelling enough to audition.
Will see if anyone has anything else to add on the subject here...
Thanks.
stu
Reply #3 on:
18 May 2013, 12:21 am »
Hi Spread,
I have been using the PWD with D500's for a few years now. I upgraded to the MKII version of the DAC when it became available. I run the DAC straight into the amps, and the combination sounds marvelous! I am sure your experience will be the same. Dusty's amps are outstanding.
Mark
spreadspectrum
Reply #4 on:
18 May 2013, 01:07 am »
Thanks Mark, that's great to hear.
I presume you have the lower gain variants of the amplifiers. Out of sheer curiosity, what is your typical range of volume settings on the PWD ? While I definitely prefer going amp direct, I start to notice the reduction in dynamic range when I get below 40 or so, depending on the media's resolution.
(For fear of being forever likened to a topping), Ryan.
stu
Reply #5 on:
20 May 2013, 01:40 am »
Spread, (it's too late to change now!)
I have ben using a preamp until recently, so I have the normal gain on the amps. I may go back to a preamp someday. As for volume settings on the pwd, it is all going to depend on your speaker's efficiency, room size, and how loud you like to listen. I have a dedicated room and like to listen at live levels, so I am usually in the 48-60 range on the volume. most of the time it is around 51-53. it will vary with the recordings too. I have had some classical disc up in the 70 range in order to get the volume right. If you go much below 45 you may notice a loss of dynamics. Another option would be a nice passive preamp. Then you can set the volume on the pwd in the 60-70 range, set the passive volume where you would normally listen, and then tweak the volume as needed with the pwd remote. Dusty makes a really nice little passive, and I have one. (Another shameless plug for Dusty)
Mark
spreadspectrum
Reply #6 on:
20 May 2013, 02:00 am »
Topping or no, thanks for the information. Obviously, there are lots of variables at play regarding the volume. Much as in your situation, I had been using a preamp for a while. All things considered, I prefer the increased transparency and three dimensionality without the preamp, even with what I perceive as a small hit to dynamics at relatively low volumes. Even so, I often find myself a bit bothered by it (the dynamic issue).
Now, if Dusty made a balanced passive pre-amp...
CIAudio
Facilitator
Reply #7 on:
20 May 2013, 04:31 pm »
If you are using balanced, I'd go with the 26dB version of D-200 MKII as you will have an extra 6db of gain over single-ended.
spreadspectrum
Reply #8 on:
20 May 2013, 05:11 pm »
Indeed, all talk about pre-amplifiers aside, that has been my plan as I suspect the 26 db version of your amplifiers would be a reasonable combination with the PWD.
Will be placing an order in the near future, as funds become available.
Owner's Circles
CIAudio
