0 Members and 1 Guest are viewing this topic. Read 4887 times.
Perhaps...--Used Mac Mini via USB to XDA-1 (or m2tech usb2spdif if the XDA-1 USB port doesn't support 24/192)--Oppo Digital BDP-103 with HDD to Denon (and/or XDA-1). No streaming and the macbook pro doesn't have to be in the picture as you can control both with iPhone apps. You can set up the mac mini with a uPNP server for the Oppo digital if you don't want to connect a HDD. Keep the ATV/AE in the mix as some might find these a bit difficult to use. Also don't rule out a used Bryston BDP-1, Olive, Naim Uniti/NDX as sources and all have iPhone apps.
Well, I tried using the PS3 to play 24 bit ALAC, FLAC, WAV and AIFF files with several different sample rates off of a thumb drive, and sure enough, all gave me a "file type not supported" error! Sony, what gives?
There are some system settings for audio, did you go in and check that there were checks next to each file type you want to play? If I recall correctly, not everything is setup to playback hi-rez or other file types [i.e. 88.2 kHz etc]hope this helps.
