0 Members and 1 Guest are viewing this topic. Read 43181 times.
You mean it will absorb power that would not have gone to the driver. (Or not used by the driver, or reflected back into the amp, etc.,)
It seems that if you are building a multi-way system with a passive crossover network you pretty much have to zobel the drivers in order for the system to work as designed. Scotty
A Zobel will not effect the sound of a transducer IF the power amp is a voltage source and there are no components in between. Obviously, if the power amp is a tube unit and there is a crossover network in between, then you have two large variables that will contribute to audible differences when using (or not) using a Zobel network.Quiet Earth is correct with his power comment.....assuming the voltage source and no crossover configuration. In that case the driver will "absorb" the same amount of power regardless of whether a Zobel is used or not.Cheers,Dave.
I disagree. A power amp is a current source basically. A tube amp is more of a voltage device and the output must go through a transformer to drive low impedance. "assuming the voltage source and no crossover configuration. In that case the driver will "absorb" the same amount of power regardless of whether a Zobel is used or not."What are you talking about, a full range driver with no crossover, but with a zobel?How do you know about the sound of a zobel, have you tried them?You can't put anything across the terminals of a loudspeaker without its affecting the sound. Try it and see. All the components are reactive, including the voice coil inductance. neo
I think what Davey is saying is that a SS amp with a big enough power supply and output capability will deliver the same voltage to its output terminals regardless of the load impedance, if it can do this it can be described as a constant voltage source. A tube amplifier does not supply the same voltage to all load impedances. It has usually has more than one tap on its secondary to accommodate loads of varying impedances, it tends to deliver the same amount of current to each tap and corresponding load value, in this way it can be described as a constant current source amplifier. Davey feel free to correct me here. Scotty
I think what has neo confused is the concept of vacuum tubes being voltage amplification devices and solid-state being current amplification devices. That's essentially correct, but the final (larger) product they're used in here....audio power amplifiers....most closely match a theoretical voltage source and not a theoretical current source.Cheers,Dave.
