0 Members and 1 Guest are viewing this topic. Read 21752 times.
In any case, the fact that the new firmware supports multi-channel dsd playback is also significant I think. There has not been a way to do this with my external Teac dsd dac and I lack the capacity to do what Ted did with the multiple Myteks. So I look at this as an affordable way to playback dsd downloads (not just discs) in multi-channel format.
I haven’t played with multi-channel yet; that will require a little more setup and configuration. I’ll compare DSF files to SACD discs as I did before. I’ll also compare DSD multi-channel file playback to my music server multi-channel setup: Foobar controlling and transcoding DSD to 24/88 PCM and sending it to the Oppo via HDMI. That should be interesting.
But here is the big question:In what way will these files sound that much better than the discs that can be played in these Oppos all along. I mean, it's great to have DSD playback but like any PCM computer playback...the beauty is being able to send the hirez content to higher end DACS. But in this case, the DAC is the same one you are using for the discs you just ripped!! So, net/net...Russ...tell us how much better the files sound than the disc. This will be a most telling a/b cuz for the first time the only difference is file vs disc (i.e same DAC in the player).
Have you tried taking the signal from the digital out to a DAC? I wonder what you'll get. I know you can't get digital signal from SACDs, but what if the input is a DSD file.
I read somewhere that Oppo's SACD spinning is not pure DSD playback (convert to PCM?) in the first place, as compared to those expensive transport + DAC units from EMM Labs, Esoteric, MSB, dCs, etc.If that's true, does this have any bearing on DSD file playback by Oppo versus other DSD DACs' ?Thanks.
Of course a $7k-15k playback setup will likely outdo a $500 Oppo!
