0 Members and 1 Guest are viewing this topic. Read 9793 times.
In any event, I already answered that the pair for sale (now SOLD) was NOT the pair from the "initial" review, but from the "second" review.
And I bought those RM-40s from Opnly a few years ago. If anyone can tell me what changes are needed to the crossover to move the mid panel cross over point up to 260 Hz I would appreciate it.Also I am looking to replace the twin spiral tweeters with AC G3 ribbons I picked up a year or so ago, I'd love to have that help on this crossover change also.
I completed the mid woofer upgrade, adding the new driver and changing the xo. I received the parts and instructions from Brian, so these 40's are up to date in that aspect.
I'll explain the apparent contradiction. The old BG single ended alnico magnet planar midrange crossed @ 166 Hz. The 5' long BG panel crossed about 115 Hz. The push pull neo planar that replaced the BG crossed at 260 and this pole never changed. I owned speakers with every one of these drivers. Multiples in fact. The neo panel will quickly self immolate crossed lower than 260 Hz. Brian stretched it as far as it could be stretched from the start. The difference in low end cutoff is one striking advantage the older panel had over the newer panel. I know this from personal experience, testing them with brian with his test mic and computer readouts and ABd them several times. None of this is 2nd hand passed along info as per the authors of every link posted here, which sum total value to me is nothing re. the spec in question.None of these authors tested anything. Readers are welcome to believe any mythology you please. PS: I'm not saying this happened in this instance. But it is highly possible Brian mis-quoted the spec too in writing and this myth became "fact" somehow, passed around amongst the authors. A mid planar panel crossed @ 166 looks better than crossed at 260. Brian once told me his sensitivity formula is to add 3 dB overall for the passive, which is a bit of a stretch. Yes, the passive increases sensitivity, but not to overall bass output, only in the lowest half octave. It's just a mass of air like that in a port. Brian's sensitivity specs back in the days were 4-6 dB over stated. Some other makers did the same, so I'm not singling him out. I remember the original SOTA speaker Brian was designing. The cabinet arrived at .33 cubic feet while Brian specified almost 1 cf. Stuff happens. In that case it was someone else's fault I won't name now. Brian and I joked for decades about one demo he did when I was there with a mid range missing from one old Mini Tower (behind a grill)...Brian loved his sound room being super dark. We laughed about that incident for many years.
immolate........ a truly great word. Anyhoo, Yes I found many quotes on VMPS x-over poles that were probably wrong. There is also the probability that some kits were built wrong and that Brian threw some oddball builds out there over the years. I have a pair of RM-1s from the same production (serial #s) that had one of each x-over! I was having a bass driver repaired at the "factory" and Brian peered in the speaker cabinet and gave it the oddest look. A look you wouldn't forget. When I got home I popped off the driver and the guts were different. Later when I had the bass system modified by a local speaker builder he measured them and replaced some parts to make the poles the same. Brian never said a word. I bought them used so who the hell really knows.
1) I guarantee readers: for every single VMPS speaker employing neo push pull planar mid panel, Brian's intended HP crossover pole was approximately 260 Hz. Any statement contrary is incorrect. But........... 2) Several fine points muddy the water:
...Also, it shouldn't be too difficult to measure a few different crossovers. Get some actual inductance and capacitance readings. One could then input the values into one of the many online sites, that have crossover calculators. That should provide a rough idea of crossover frequency. Plus, maybe show if Brian tweaked as he went, and crossover points shifted up or down, over the years...?
Can anyone explain how to measure capacitors and coils?
Your second point makes your first point invalid.I will not argue with you, but I believe you are wrong.Brian giving incorrect information to reviewers (and on the webpage) would serve no purpose, but yet it is (was) documented in several places that the first version with the dual spiral tweeters crossed at 166 hz and 10k hz and the improved version with FST crossed in the high 200s and low 6k range.Your "guarantee" is worthless IMO.
Seems to be a bit of confusion here. Maybe I can sort it out.First the initial review written by Marty is for the "FIRST" pair of RM40's Brian sent him which had dual Spiral Tweeters and the 166hz XO.The second pair which we just sold, had the FST tweeter, and was built "after" Brian had decided to raise the XO to between 220Hz and 280Hz (he was experimenting a bit with different models depending on the woofer).The other two RM40 reviews referenced above that mention the 166hz XO point clearly also state that the pairs had the twin Spiral Tweeters and not the FST.I am not sure about the RM30 review (Roger might remember), but it was the new RM30 that caused Brian to raise the XO point, so either Rogers pair was so early that B hadn't raised it yet, or he was given misinformation (or used "old" information) in the review.So to recap: Early VMPS panel speakers (after I came on board) had XO's as low as 155hz - 166hz and then raised in all models to 220-260hz.The primary reason for the change upward, was to allow the dynamic cone woofers to increase the impact and air movement to sounds like snare strikes, rim-shots, and other percussive dynamics which needed "more air" to move. It was also one of the reasons Brian designed the RM30 with the intention of having twin 6.5" megawoofers to create that impact. And soon after he also started using improved MegaWooofers, finally ending up with the latest MegaWoofer with 40oz magnet.In any event, I already answered that the pair for sale (now SOLD) was NOT the pair from the "initial" review, but from the "second" review.Openly Baffled (on AC) purchased the first pair from Marty with the twin Spirals.
John, Just for other reader's knowledge, not to hammer you at all. You know not what you speak re. the neo panel crossover. I have read you post things about VMPS maybe 100x that were half truths and complete fabrications. I'm not blaming you at all, seriously. I can only presume and am happy to presume in every case they were honest errors and never meant to trick or harm anyone. I'm simply posting this to let readers know your information above is false concerning several items, specifically one of them Brian changing the neo crossover from 166 to 260 Hz. Please state your exact source. If it was Brian, say so. If anyone here and now claims there ever was a 166 first/highest pole for the neo panel, this is false. No such pole ever existed. Quoting what a review believes in pretty stupid on this particular subject when they did not test the specs. That was the pole for the old alnico bg panel.
Now I am confused, you have several posts dated back in August of ’03 talking about the 166hz crossover. Here is a quote from one of those posts,“The tube amp drives a passive high-pass crossover, which filters the bass frequencies, then that filtered signal feeds only the upper range drivers. In the case of VMPS, that would be the ribbon mids & tweeters from 166Hz up.”
