SOLVED: NC400+SMPS1200A400 - no sound
0 Members and 1 Guest are viewing this topic. Read 12826 times.
tarnumf
« on: 17 Mar 2013, 11:56 pm »
Hi,
I'm trying to put together NC400+SMPS1200A400 as stereo amp and cannot not get any sound out of it :(
Everything lights up, and I can see some output in range of ~10 mV, but this is it...
Double checked all connections and cabling.
Would greatly appreciate any help, please!
Here is the how I connected SMPS1200 to NC400 12-pin connector:
Overall picture:
« Last Edit: 19 Mar 2013, 01:06 am by tarnumf »
tarnumf
Re: Please need help: NC400+SMPS1200A400 - no sound
« Reply #1 on: 18 Mar 2013, 12:48 am »
Bigger images:
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 18 Mar 2013, 11:14 am »
Where's the Nampon?
FloridaBear
« Reply #3 on: 18 Mar 2013, 01:58 pm »
I can see nAMPON looping back into the shrink there, but I don't know where it is wired--it should go to ground. Two other observations:
  • Your speaker wire leads should both come off the same side of the terminals according to Bruno (i.e. both on the left or both on the right in the picture). Yours come out on the "outside" of the terminals.
  • Also relating to the speaker wires, the + and - should be twisted together. You have the + twisted and the - twisted (I assume you are using two wires to decrease the effective gauge).
EDIT: other than that, very nice, clean job with the wiring.
tarnumf
« Reply #4 on: 18 Mar 2013, 03:06 pm »
What is nAMPON? Is it "Driver voltage"?
Thanks for notes on output wiring, will re-arrange them when I get some juice out of them..
jtwrace
« Reply #5 on: 18 Mar 2013, 03:13 pm »
The extra black wire on your input wiring is for Nampon.  It goes to ground.  Either direct or through a switch which then becomes your "mute".
FloridaBear
« Reply #6 on: 18 Mar 2013, 03:36 pm »
By the way, what SMPS is that? It's not the NCore-specific one.
tarnumf
« Reply #7 on: 18 Mar 2013, 04:11 pm »
The thin one? Bingo! They are not connected to anywhere.
tarnumf
« Reply #8 on: 18 Mar 2013, 04:12 pm »
SMPS1200A400
jtwrace
« Reply #9 on: 18 Mar 2013, 06:02 pm »
Yes, attach it to chassis ground and you will get sound.  Hopefully.
Bubbleboy76
« Reply #10 on: 18 Mar 2013, 07:23 pm »
Very nice build! Looks like the Galaxy Maggiorato case from Hifi2000?
The nc400s will run 5 watt hotter with SMPS1200 than with SMPS600, but you probably know that. I also use SMPS1200, and I use an extra ventilated top-cover.
ufokillerz
« Reply #11 on: 18 Mar 2013, 07:45 pm »
definitely doesn't look like a hifi2000 case
looks like one of the many cases available on ebay from one of the sellers in china or hk, my monoblocks from china look about the same just shorter.
tarnumf
« Reply #12 on: 19 Mar 2013, 12:45 am »
Thank you all for help and kind words! As expected, as soon as ampon wires got connected the thing came to live  :thumb:
Vanity shots and build details are in Show Us Your Core-NCore!
- no, I don't, but it's OK for Chicago climate :) . So far it runs quite cool.
jtwrace
« Reply #13 on: 19 Mar 2013, 12:46 am »
Welcome!   :thumb:
roscoeiii
« Reply #14 on: 19 Mar 2013, 12:49 am »
Good to have another Chicagoan on AC.  :thumb:
Smithysurf
Re: SOLVED: NC400+SMPS1200A400 - no sound
« Reply #15 on: 20 Mar 2015, 08:53 pm »
Hi do you combination of amp and power supply work ok
