0 Members and 1 Guest are viewing this topic. Read 7913 times.
Good call - cast iron is WAY better than nonstick crap. Plus, you can sear something super hot on the stove top, then transfer it to the oven to finish cooking more slowly. Nonstick can't really be transferred like Cast Iron can. Hell, they were originally built to be used over campfires for the settlers, can't get more rugged/tough than that!
Cast Iron pans have their place. They're good for browning things and they do become non-stick. There's only one problem. You shouldn't cook acidic foods in them. That leaves out cooking with wine, tomato etc., otherwise your food is apt to taste like rust.Doc
You people are the best. Always wanted a good cast iron skillet. Found this on EBay and bought it. Not one but three skillets pre seasoned. Now I need a good Merlot to go with my first dinner. From Green Mountain, brand new.
Every kitchen should have one good non-stick fry pan. Unfortunatly it's going to cost you $100. Cheap ones are just that, cheap.Doc
I've been using cast iron for decades and have not found this to be true. If you cook acidic foods in a new cast iron skillet, it might be valid, but a well seasoned cast iron has as much as 1mm of carbon coating the bottom and sides of the skillet, and carbon is very slow to react with acid. There is essentially no contact between the iron and the food.
I was looking at Tramontina Professional pans? What do people suggest? I have no interest in cast iron.
No coated non stick pan last a lifetime, unlike cast iron which are good for multiple lifetimes. But at $30 apiece, they only have to be a bit better than the Tramontinas that I usually buy for around $25.
