0 Members and 1 Guest are viewing this topic. Read 22031 times.
There's always a better mousetrap to be discovered.
It must have been an old tube frame model; I test rode a buddy's Cyclone one cold day in 2002 and couldn't wait to get back on my Guzzi. I hated it.I thought about it for a few days and it reminded me of a Norton so I test rode an X1W a few weeks later and the rest is history.They smooth out around 75 MPH so aren't the best city traffic motorcycles.They do handle better than anything else I've ever ridden which has proven to be a good thing when I enter a corner going a little too fast. Uh oh...So as to not totally derail this thread:http://www.audiocircle.com/index.php?topic=103786.0What would the drawbacks be to a carbon fiber frame for the Magnepans (other than cost)?
You bet.My main objective in building those frames was to try and ignite the DIY spirit in some users. I purposely made the joinery easy and utilized standard wood dimensions that could be very easily obtained. No router is required....no dado's....no 45 degree cuts....etc, etc. You just need to make some easy crosscuts and rips. A cheapo table saw or even a portable circular saw with clamped straight-edge will work fine.Some folks appear to put greater weight on the aesthetics of a project....and that's just fine. However, the concept here was simplicity, value and performance.But what do I know. Dave.
My thought would be it would complement or replace that purpose of the wood frames, but then I'm no engineer. The wood frame mod is very popular, but as is, cannot be the SATA of frame construction. There's always a better mousetrap to be discovered.
The wife is on the warpath so it's just as well I'm far away from the old sweet heart and the blizzard of dog hair which passes for the family dog.
And rectangular isn't really great for dipole baffles. I'm actually surprised we don't see anyone experimenting with different shapes. The idea is to smooth amplitude response by distributing the path length.
But what do I know.
quite a lot!
That doesn't seem correct to me.Unlike the Apogee's, which are tensioned quite differently from top to bottom, the Maggie transducers are tensioned quite evenly. The bass resonance "peak" is narrower (and less in amplitude) in Magnepans...relatively speaking...such that a more defined front/back cancellation distance (path length) should/would be required.The trapezoidal shape of some other planar speakers would be appropriate for them....depending upon how the transducer is constructed....but not necessarily for Magnepan's.But what do I know. Dave.
Gee, there was a Hodaka that was almost identical to my first - a Steen 100. As a kid, I had a blast with that thing (oh, what my parents never knew...).I think it's Jim's turn to clean up, isn't it?
