0 Members and 1 Guest are viewing this topic. Read 31518 times.
Well, I can post it right here for starters.In Scandinavia, there are several sources cases. However, my preference is the Monacor (www.monacor.dk) cases, and I have been quite succesfull in using some of their 2 RU cases.The case has number UC-262H/SW (part No. 332540). I'll get the direct link later.Cheers,Jens
Hi,Just bought a few items from http://www.diyplus.net/ A Taiwan site. Their case are slightly wider and deeper than most so will suit those who need something a bit bigger. I got 2x EPlus80 (multi RCA) and 3 face plate and 50 PCB feet. Weight about 8.5KG and cost NTD $1620 to NZ. Apparently the post office have charge less (should be $2740) and CSW, the owner kindly refund the extra that he charged me. Which is good of him.Stock arrived within 5 days and in good condition and he even provide cotton glove so that you will not leave finger print on the case!!Oh yes! The PCB feet will suit those who find it daunting to drill small PCB mounting hole. Will also suit those who can't decide the best way to arrange the PCB inside a case - like me . For those who have problem with Chinese, the face plate are sold separately. NTD$530 for the 6MM std EPlus80 when buy together with the case. $620 if only the face plate itself. Chinese word 元 = $. CSW, do answer email in English but be aware that English is his 2nd language.The case is a one piece aluminum cut and folder into shape with an "n" shape cover. Overall a good quality & solid aluminum case. Recommended. Have fun...
