0 Members and 1 Guest are viewing this topic. Read 28667 times.
I ordered G2 tweeters from Parts Express and replaced them. Had awesome sound again for about an hour then poof...two red fire balls at precisely the same time (one from each tweeter ribbon). What the heck is going on here? Both tweeter ribbons burn up at exactly the same time. Do I need to put in new TRT caps or something? Is it a problem with the bryston amp? I am still under warranty with Bryston as it is only 14 years old now. This happened on the original tweeters that Brian installed as well. This time I had the Marantz Av7703 hooked up with XLR's to the Bryston 6BSST and the other two times it was with the Sunfire TG III connected to the bryston. Source material was a "Beck" SACD being played with an Oppo 205 in all cases. Oppo was connected by RCA's from the analog out stereo L and R outputs to the receiver CD L and R inputs.Any help would be appreciated as I don't even know how to take the RM40's a part to check anything. Could someone please describe how to take the RM40's apart to look for damaged components? I have a good FLUKE MM and I am pretty handy and can solder basic stuff. What tools do I need and does anyone have instructions on how to change out or instal new caps like TRT's?Thanks and please feel free to call me also as it may be easier to figure out a solutionScott(408) 221-9878
I need a replacement 12 inch woofer for my FF1. Does anyone have one?
Somebody made all the drivers for VMPS. Just because VMPS went out of business does not mean VMPS suppliers went out of business. In a loudspeaker like Ohm, which makes the unique Walsh driver themselves, then if Ohm went out of business you would be out of luck as far as factory replacements. Bohlender-Graebener will probably keep improving their ribbon panels, because it's a competitive marketplace, and if not, somebody else will step in. With VMPS gone, there is a void in affordable neopanel speakers that somebody else is bound to eventually fill.
