Hi
The advantage of the USB asynchronous circuit in the DBA2 is the data is transferred I2S from the USB to the DAC and does not have to go through the SPDIF conversion.
So I assume from the comments that most believe USB signal transfer is not performing at the level a sound card and AES or BNC or COAX SPDIF does?
James
If you had i2s from the start you wouldn't have to go through the USB "conversion" either..
You now have to worry about:
* linux usb audio driver making decisions based on the USB DAC connected to it
* Does the usb audio device chip recover the clock from the USB signal and drive the i2s clock?
or does it synchronize the data and use another clock to drive the i2s clock?
Perhaps you are removing a sound card and s/pdif to i2s step, but the data will still be the same here. USB flow, it depends on the setup, which I'm sure you can control with the BDP-2, but not with other DACs.
What is Bryston's support model with other USB dacs if the BDP-2 supports non-Bryston USB DACs? I would expect folks to just add a BDP-2 to their AVR USB DAC input or other USB DACs. Not all USB dacs support 192/24 audio, you the BDP-2 would have to allow the generic linux USB audio driver to downgrade the audio. Does this open up a can of warms for support?
Jim
