0 Members and 1 Guest are viewing this topic. Read 32116 times.
and two mirco-SD card slots to fit another 128GB into
Vinnie,Astell & Kern say the SD slots accept cards of 32GB max - have you performed some modification to extend the maximum to 64GB?Steve
Hi Vinnie,Just your view on this mini-Toslink digital output (that also outputs up to 24/192k) please?It is standard optical transmitter inside AK100?Regards,Janis
Vinnie, As best I can tell, the RWA mod is just for the analog output stage? Is there any benefit to your modded units if this is intended primarily as a transport?
I have second thoughts one can just bypass the output resistor in series and all is fine, without any secondary effects. Wouldn't it have been wiser to bypass it with a lower resistance, say 4R7 for a total of 3R9?
What other circuitry is bypassed beside the respective resistor?
Also, I got word of a AK100 follower, which is supposed to have a "much lower" impedance and dual mono DAC chips, got anything on it that you can share?
Hi Steve,It has been tested by AK100 owners that it works fine with 64GB micro SD. You must format the 64GB microSD card to FAT32 to see the whole 64GB. With Mac use your disk utility for that.Best regards,Vinnie
I have read that the volume knob on the a k100 feels cheap and inconveniently sticks out. Are there any thoughts on a non /s mod that addresses this and retains the use of the internal amplifier?Cheers,Scott
Off-topic:Vinnie - any comments on DSD sound quality through the AK120?
