0 Members and 1 Guest are viewing this topic. Read 92684 times.
Cheers to all, VMPS is unique in this world. Hope someday another manufacturer takes up the reins and continues this fine tradition of phase coherent, planar midrange speakers!
Can anybody tell me what the exact crossover frequencies are for the RM40's? Mine are about 8 - 9 years old.Also, if the upper woofer (mid-woofer?) crossover frequencies are the same as the lower?Thanks,
Thanks, John.I think my woofer to mid x-over is 166Hz. My speakers have the upgraded top woofers as the seller provided me the originals as extras.I suspect my mid - high x-over is 10kHz but I recall reading that the later versions had the x-over frequency lowered to 8kHz or somewhere around there.I take it there's no identifier that would confirm my speaker's age and hence the x-over frequencies?If not, then why the hell did I spend such big bucks ($1,500 + $500 shipping) on these fabulous speakers when I could have spent far more for far less? The main thing I wanted to know was if I have a 4-way or 3-way x-over. Any help there?Thanks,
Two more questions if I may: 1. Are the speaker binding posts easily replaceable? e.g. do I need to perform any soldering? 2. Are the internal wires (i.e driver wire to x-over, x-over wire to binding posts) easily replaceable? e.g. do I need to perform any soldering?
Thanks, John.I should have been more specific. I'm bi-wiring but the purple Analysis Plus jumpers that came with the RM-40's have ring terminals at either end for easy fastening at both binding posts.If I purchase the right binding posts, do the internals have ring terminals for easy fastening?
Can you tell me what binding post size and length I should be looking for?
And finally, do you have an outright recommendation on some good copper, rhodium, or silver binding posts properly sized for the RM-40's?Very much appreciated.
Are there anymore Large SW upgrade parts? Megawoofer and or PR's ?
Can anyone tell me who was the manufacturer of the RM40 10" upper and lower woofers?Thanks
