0 Members and 1 Guest are viewing this topic. Read 4603 times.
Ok Jason,But I'd like to know what the number for the input efficiency is, so that I can determine whether I can drive it with my phono pre.Jos
Input sensitivity is a number that's normally stated in the list of specifications. If it were, for example, 1.5 Volt, I wouldn't be able to drive the Virtue properly with my pre, since it, the Virtue, would need an input of 1.5V to be able to reach its full power.Jos
you can reach full power without the full 2 volts of input power, in fact you can usually reach it with about 60-75% of that.Jack when your limited to either 50 or 90watts then in many cases yes full power would be required by many.not to mention its like a new muscle car. "Punch it, let's see what this baby can do"
Hi.Not everybody wants to bring a rock concert back home, bud!c-J
Hi guys,I play with a 5 Watt tube amp. For me it's not about the power but about the dynamics. If your input is too low relative to the i.s. of the amp, you can crank up the volume whatever you like, but the music won't come to life.At least, that's my experience.Jos
there's something about "Money for nothing" that drives me to blow up drivers
That entire album is Amazing, songs are great - , it won a couple of Grammys actually, and for its time it's a really clean DDD release. Scary thing is (speaking of an early CD circa 1985) that it's like 15dB or more down from peak. Other releases might have had that changed, but for mine I eventually ended up ripping it as Wav in EAC and boosting the amplitude on each song considerably to 2dB off peak using CoolEditPro ... then slow-burned that to a 100 year metal azo. Now that one will rattle the windows If people haven't heard this album all the way through, they should go do that immediately. M.F.N. is the only 'rock' song on it, it's clean, brilliantly done, the soundstage is huge, it's both well-defined and varies, it envelopes you, and on M.F.N is actually revolves. LOVES good amps and speakers, very rewarding.Now I gotta go find it, haven't heard it in a while...
