0 Members and 1 Guest are viewing this topic. Read 46954 times.
Do you have the 10" Peerless SLS Subwoofers or regular woofers? The subwoofers: http://www.parts-express.com/peerless-830668-10-paper-cone-sls-subwoofer--264-1110 have a Q of 0.55 and Fs of 32 Hz. Or the woofers: http://www.madisoundspeakerstore.com/approx-10-woofers/peerless-sls-830668-10-woofer-coated-paper-cone/Looks like the woofers are not sold by PE anymore, but the subwoofers are. Maybe the subwoofers are just a new version of the woofers?Are you still planning on powering your quad subwoofers with a Yung plate amp? Do you envision needing any additional frequency shaping or active components in the H-frames to work with the Hestia-SL tops?
Hi Ed,Glad I waited to buy my drivers - the Lil Buddy sounds like a great upgrade. You mentioned that the crossover basically stays the same except for a couple of resistors to balance the sensitivity in the system. What value resistors do you suggest?At least for now I'm stuck with an amp without pre outs so I will try to build a different low end. Do you think a single Alpha 15 (passive) in a H-frame configuration would work? Later when I find an appropriate amp/pre I will upgrade to the SLS with a plate amp.John
Hi Ed,Having been on a speaker building sabatical for a couple of months now, I've started assembling drivers and parts for the Hestia-SL only to find a couple of new impressive design builds with the Hestia V Dome! I had planned to use the Lil Buddy as you suggested, but I see two new different drivers in the V. I've heard the Seas before and really like it. I also see the Eminence Legend as a replacement for the Lil Buddy. Wondering if I should continue on the SL and move up to the Hestia V. What are the sonic advantages?After a conversation with a friend about a low end driver, and in an effort to keep the overall profile on the slim side, he suggested as an upgrade to my Alpha 15, the Eminence Definimax 4015lf.John
