0 Members and 1 Guest are viewing this topic. Read 13979 times.
The B&C driver is not a servo driver so how does work with a servo amp? Rocket_Ronny
So, what would be the best option, both from the pure sound quality point of view, and also compared to the price?
Drivers like AE Dipole series and Hawthorne Augie are designed for flat response in OB without EQ. They have high Qts like .7 to allow exaggerated cone excursion (floppy cones.)
You're going to have trouble using the DEQX to provide dipole correction in the bass. It doesn't provide enough boost.
Hi JohnR. I don't know the dipole 15, but doesn't the q of the driver go up when placed on the baffle. So if the dipole 15 has already a q of .7 perhaps thats why the bass is slightly ill defined. Not sure just thinking out loud. Regards.
But I have read that the actual q does go higher when placed on a open baffle.
Actually Steve, I had no such problem using my DEQX with a set of W-Frame dipole subs. It would easily correct for the dipole loss down to 18Hz. The drivers were SCC300. YMMV.
Hm. Well, I'd appreciate a link, or further info, if you have it.
The only way to cause an increase in Q is to mount in a box or an open-baffle configuration/construction that creates some sort of appreciable air loading.
In no expert, so maybe there are other explanations, but the tightness and pitch definition in the bass that I get with the lower Q woofer is certainly better than that of the AE. I did not think that a higher Q with such a low FS would affect the over 60Hz region, but it seems to have. I even tried the L-pad across the second coil of the Dipole 15 for an adjustable Q and it changed the measured response by a few dB and sounded a little clearer, but not as good as what I ended up with. Now, one has to be careful with these type of comparisons because to many people, less real low end response can be interpreted as sounding more defined and tighter. So take whatever I say with a grain of salt, but I did spend a lot of time experimenting, measuring and evaluating all possible options with the AE Dipole.
I heard Mr. Pass' system with the slot loaded woofer at this years Burning Amp. I am planning to build my own version. The bass sounded good even in a room obviously not intended for hi-fi, and by putting the slot next to the floor and the driver behind the open baffle it is less visually intrusive.
