0 Members and 2 Guests are viewing this topic. Read 180306 times.
Does the e20 from ExaSound have a FEMTO clock?I am puzzled as to why you think it has better specs than the Auralic:With Sanctuary Audio Processor as heart, AURALiC introduces several cutting-edge technology for VEGA: Megahertz upsampling algorithm up-samples all PCM music to 1.5MHz in 32bit; Femto Master Clock provides an ultimate clock precision with jitter only 82 femtoseconds(0.082 picosecond). Binding with other AURALiC's patented technologies such as 'ORFEO Class-A module' and discrete 'Purer-Power™ solution', VEGA will bring high resolution music playback experience to climax.b]
I just picked up the Lynx Hilo, which with the latest firmware, is promising DSD playback. I've only it had it for a week and have only enjoyed red book and high res. material. So far, it's a fantastic sounding DAC that should scale well in the future.
The exaSound e20 and the AURALiC VEGA are extremely close in performance - just look at a comparison of more of of the stated specs. I really don't think you can just look at the master clock jitter and not compare the rest of the performance figures.e20 Upsampling Not stated VEGA Upsampling 1.5 MHz.e20 master clock jitter 0.13ps VEGA master clock jitter 0.082pse20 THD 0.0002 % VEGA THD 0.0003%e20 Signal/Noise 128dB VEGA Signal/Noise 126dBe20 IM distortion 0.0000079% VEGA Not statede20 Channel separation 130dB VEGA Not statede20 Dynamic range Not stated VEGA 130dBe20 Inputs 1xcoax,1xtoslink,1xUSB VEGA Inputs 2xcoax,1xAES,1xtoslink,1xUSBe20 Outputs XLR, RCA, headphone VEGA Outputs XLR, RCAI have no doubt that the VEGA IM distortion & VEGA Channel Separation will be close to those of the e20 - but if you look at the THD and Signal/Noise which are equally as important as the master clock jitter then the e20 is "superior". While exaSound may not have the pedigree of AURALiC the e20 is clearly a well engineered product (as is the VEGA) - and in some aspects the e20 is "superior" just as in some aspects the VEGA is "superior". The VEGA was designed as an audio processor - hence more inputs and no headphone socket and costs more - while the e20 is a DAC with less inputs and costs less.I don't know whether the e20 has a FEMTO clock (now a commonplace bit of silicon) - but one has clock jitter 130 fs versus 82 fs - both very small numbers - and both very good figures. It would be interesting to know the e20's upsampling rate so as to compare that with the VEGA.In the context we are talking about though with these vanishingly small numbers - in the real world the end result any noise/distortion will be so inaudible that a comparison between the VEGA and the e20 should really be a tie.Both devices support the same capabilities PCM 384K/32 bit and DSD 2.8224MHz and 5.6448MHz - so in hindsight I misspoke - exaSound e20 and the AURALiC VEGA are extremely close in real world performance figures. If you are after an audio processor with more inputs go VEGA - if you are after a DAC with a headphone socket then the e20 is also an excellent choice.
OK, I can live with that, but the Femto clock would be the decider for me. The other specs have a lower correlation with sound quality, IMHO.
Dont sweat the Femto clocking too much (the e20 does not have it by definition, as clock jitter is in the pico range). Here is what a very informed aqcquaintance told me in conversation:The Femto-clocks may be a little pointless, as the clock signal afterwards passes through IC's that add tens of ps Jitter unavoidably and I possibly see the future more with Android than iOs, but the principle remains....Actually, just for fun, the (sub-$1000 unnamed DAC) has jitter so low, I cannot measure it, it is lower than the DAC's noisefloor. The clock driving this DAC has probably around 10 - 30pS... A Femtoclock would not be able to make any improvement, nor would be a 1ps Clock...
Any new word on the 'potential' tubed DSD capable dac mentioned as a possibility above? Ted's assessment of the Meitner has me seriously thinking about moving to a DSD capable dac from my AMR dp-777......but I really like tubes !Thanks in advance for any info. Randy
The problem I have with the "adverbials" is that they are by strangers and as you both have stated sound is so subjective.What may sound good to one of you could sound flat and lifeless to another - whatever that is supposed to mean - and let's restrict this to DSD DAC's - the function of which is to accurately convert digital to analog sound - the more accurate a conversion the better the DAC. That should correlate with better sound - but I have seen enough on this and similar forums to know other factors are in play as "sound" in part is psychology - so is in part subjective. I would not argue against that - just to me DAC conversion accuracy is essential - and I want basic performance results of any DAC - clock jitter, frequency response, THD, IMD, Channel separation, Signal-to-Noise ratio etc. - the basic measurements any DAC company should supply. Placing an expensive price tag against a DAC should not preclude a company from at least providing those essential measurements. Then provide whatever adverbials they want.
Why the rant? Nobody is forcing you to go against your principles, if you are attracted to the E30 e20 then please go check it out and report back. We would all welcome that. More choice is good.
This looks like an interesting option for the DIY folks. http://www.rigisystems.net/index.php/usbpalen.html
I have recently started "acquiring" SACD ISO's and ripping them onto DVD-R's. I have a pretty good system that is extremely revealing. I have found very bid differences between players sound on SACD's!I have gone from entry Sony, to DENON DBP, to Primare BD32. The Primare completely blows away everything I have heard. But, I do not need the Multichannel or Video section...That is what leads me to this topic.I know everyone here is discussing DAC's, but is there not a DSD ISO streamer? Wouldn't this be the most efficient method. Something like a DSD version of the PS Audio Perfect Wave/Lens or Bryston Digital Player...Does anything like this exist yet?SS
