0 Members and 1 Guest are viewing this topic. Read 180518 times.
Help. I just got a ifi nano and it works fine playing 192/24 wave files on my Mac.However my music player software, Fidelia, seems not to recognize dsd files.I need a recommendation for appropriate Mac music playback software that is compatible with DSD files and the ifi nano.Thanks,Frank Van Alstine
Am I overlooking some settings in J River (which is kind of a maze for me to figure out) or is the ifi nano putting out DSD from its coax digital output with DSD in?
Thanks for the good advice Ted. I would like to pick your brain about the ifi nano a bit more if you don't mind.I am wondering just what the coax digital output of the ifi nano is actually doing.Using my Macbook pro and 192/24 wave or flac files, I can use Fidelia player software and go from the Mac's USB output into the ifi nano, then out its coax digital output into the digital input on our own Fet Valve DAC and it works just fine.Using J River and DSD 64 files, the digital output of the ifi nano is not compatible (so far) with the coax digital in on our own DAC. But it does work from its own internal DAC and provides useful but hard sounding analog output.Am I overlooking some settings in J River (which is kind of a maze for me to figure out) or is the ifi nano putting out DSD from its coax digital output with DSD in?With either the Schitt DAC or the ifi nano I have great user flexibility but the dinky little IC filter and analog output circuits both have that hard and sterile characteristics I want to avoid by using my own tube hybrid DAC as the analog engine.So far standard redbook or 192/24 wave files are better through our own DAC then DSD or 192/24 through the Schitt or ifi nano respectively.Thanks,Frank Van Alstine
Digital outputs (coax, toslink, AES) are not available for DSD, only PCM. The only way is to package it as FLAC-contained DoP, as per this thread:http://www.audiocircle.com/index.php?topic=119364.0
The new Lyngdorf TDAI 2170 does accept DSD64/DSD128 via optional USB DAC and HDMI modules. Just to mention http://lyngdorf.com/images/Downloads/TDAI-2170_Owners_Manual_-_130314_v1.1.pdf
Where is this DB you speak of?
Is this "iFi Nano" this iDSD? I have been very interested in the iDSD. May grab one after the next paycheck. http://www.musicdirect.com/p-161157-ifi-nano-idsd-dac.aspx
