0 Members and 1 Guest are viewing this topic. Read 99113 times.
Well 2.2 is one of the options for calibration. I assumed it was for a 2 channel, 2 sub set-up. Are you saying you would need 2 dual cores for the 2.2 calibration?
rodge, you could output those graphs to your computer, apply a bit of smoothing, then save the screen image as a .jpg and post it up...
AFAIK it does.you might want to give it a try either way and choose which one you like.
Can this be done? I don't see in the manual anything about this.
With compensation it's worth noting that typical calibration already introduces some compensation. In my setup, a boost of 6dB, which I suspect is indeed a "typical" value for most systems after typical calibration. In my system, increasing the boost to 7dB has had a firming up effect on the bass range and, more notably, an increase in the three dimensionality and 'air' of the soundstage.One has to keep in mind that increasing compensation has a negative effect on headroom, so going light on the throttle may be advisable here, as in any boost.But definitely a setting worth experimenting with.Guido F.
I'm finding that with typical calibration setup the maximum bass compensation is 6dB. I've been playing with speaker and sub positioning and the flatter I can get the room measurement before calibration the less bass compensation it applies after calibration. The lowest I've gotten it is 4 or 4.5dB. Does this make sense?
