0 Members and 1 Guest are viewing this topic. Read 99210 times.
I have no problem with it being discussed here and in fact, welcome the discussion. However, it is bad protocol to direct the AC Membership to leave this forum and go to another. Not being a hard arse, just asking for respect of the AC.Thanks for your understanding,Jim
Rodge had also mentioned the preamp section improves greatly on battery power, making it a dream machine indeed.
On the less expensive side, MF V-DAC users seem to like the Pyramid PSU
I stopped by the Legacy room at RMAF Saturday evening and got to see the setup procedure and demo the speakers with and without correction. I am impressed and plan on using one as a DAC with USB input and RCA out to my preamp. A lot has already been said so I'll just point out some things I learned....- It's best to output the results of freq sweeps to your computer, you can compare before/after, add smoothing and have a much larger screen to work with. I'd say having a laptop beside it while doing setup or adjustments is a must. - Bass is adjusted in mono up to 199 Hz. It might be worthwhile to try manual adjustments at 200+ Hz as well as auto correction from 200 to 500 Hz and see what's best. When we set up the unit at RMAF we just went up to 199 Hz because it takes a lot longer to run the stereo setup procedure, so even further improvements could be made than what I heard. - The normal setting is normally preferred for how much correction the unit will add. This unit is a definitely not a substitute for proper setup and room treatment, although it is possible to use less room treatment than you might otherwise, and reduce the effects of a poor room. If you have a huge bass null it's not going to be able to level a 12 dB dip...The unit can do a freq response test up to 20k Hz and you can use this feature to see what changes in room treatments and placements is making, get it as close as you can then use the correction. Add/remove room treatments then run correction and save the correction file so you can directly compare room treatments with correction already done for both scenarios. I think it can store 3 correction files, but don't quote me on that.... anyway, it is powerful tool beyond just the auto correction feature... you could spend A LOT of time messing with stuff and running freq response tests. You could use it to measure and improve a DIY speaker project...
Here are a few outboard power supply makers:https://coreaudiotechnology.com/products/power-supplieshttp://www.paulhynesdesign.com/page7.htmlhttp://www.mojo-audio.com/power-supplies/http://redwineaudio.com/components/black_lightningThere are some that I'm missing, feel free to add to the list.
Having owned mine for a little over 2 months, I can testify to it's being a good product. Prior to this, I used 2 of their 8033 mono sub units on my subs, so I pretty much knew it would be good. The DAC is quite good, too.......It is night and day - bass instruments and drums are now there in the stage, not everywhere.
