BDA-2 DAC and BDA-3 DAC
0 Members and 1 Guest are viewing this topic. Read 402141 times.
Robert D
Re: BDA-2 DAC
« Reply #160 on: 19 Jan 2013, 01:20 pm »
Thank you James
It was purchased from Claude Sons Ideal
Robert
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDA-2 DAC
« Reply #161 on: 19 Jan 2013, 01:22 pm »
Thank you James
Robert
Hi Robert - that may be the problem as he is no longer a dealer - maybe recheck with him.
james
Robert D
Re: BDA-2 DAC
« Reply #162 on: 19 Jan 2013, 01:33 pm »
James, All was cleared with his sales Rep and Bryston
they worked it out
Let me know Please
Regards Robert
gordon
Re: BDA-2 DAC
« Reply #163 on: 20 Jan 2013, 03:11 pm »
Great :thumb:  looking forward to your feedback.
James
OK, 48 hours into this (Mac mini running Pure Music / iTunes into BDA2, into BP26 & 4BSST, into B&W CDM9NT's) and the BDA2 has taken it to a whole new level. It replaces BDA1 + Empirical Offramp3, which had been a very good combo for USB. Now the BDA2 in place of both is proving to be a big improvement in each of 3 major areas; resolving detail, avoiding any harsh or fatiguing elements and a more precise and expansive soundstage.
Overall not a subtle change, a great step up. Hope Bryston gets the press and business it deserves on this new DAC, bravo James.
gordon
Re: BDA-2 DAC
« Reply #164 on: 20 Jan 2013, 03:14 pm »
Oh yeah, key music played so far: John Williams The Magic Box, The Unthanks cd Last (highly recommended), a lot of Sarah Harmer and Mark Knopfler.
Cheers
Re: BDA-2 DAC
« Reply #165 on: 20 Jan 2013, 03:29 pm »
Hi Gordon -  thanks for the feedback. Have you tried Amarra or Audirvana or Bitperfect as well?
James
gordon
Re: BDA-2 DAC
« Reply #166 on: 20 Jan 2013, 06:30 pm »
James
Am a past Amarra user, switched to PM and no reason to look back.  Have not tried either of the others, back to music listening vs system tweaking for awhile!!
Re: BDA-2 DAC
« Reply #167 on: 20 Jan 2013, 06:52 pm »
Thanks - I am running blind tests with the 4 different programs.  I assume you prefer Pure Music over Amarra?
James
gordon
Re: BDA-2 DAC
« Reply #168 on: 20 Jan 2013, 09:01 pm »
James
Yes, subtle difference but for my ears an improvement and also found the whole purchase/support/set-up a little more suited to my modest technical ability. Eager for your views once your through the test.
Cheers
Ottawa HiFi
Re: BDA-2 DAC
« Reply #169 on: 23 Jan 2013, 03:10 am »
Glad to see some positive user experience with the Bryston BDA-2.
Can't wait to get my unit back from Bryston.
James, are you testing my DAC as we speak?  Curious to see what you think.
Jules (A.K.A - Ottawa HiFi)
Robert D
Re: BDA-2 DAC
« Reply #170 on: 23 Jan 2013, 12:58 pm »
Jules wheh did you send your unit back to Bryston ?
Robert
Ottawa HiFi
Re: BDA-2 DAC
« Reply #171 on: 23 Jan 2013, 01:08 pm »
Robert,
I sent the DAC in last week.  Officially they got it last Friday.  Not sure what the turn around time is,
but I am sitting tight to see if anything can be resolved.
If nothing is wrong with the DAC, then I have a serious problem with my audio system that I need to fix.   :scratch:
As soon as I get the DAC returned to me, I will be updating AudioCircle.
Jules
Re: BDA-2 DAC
« Reply #172 on: 23 Jan 2013, 01:15 pm »
Robert,
Jules
Hi Jules
We are checking it out now so will let you know as soon as we figure out if there is an issue or not.
james
Re: BDA-2 DAC
« Reply #173 on: 23 Jan 2013, 03:38 pm »
Hi Jules,
We have looked at your BDA-2 and electrically it is working perfectly.
james
Xinon
Re: BDA-2 DAC
« Reply #174 on: 24 Jan 2013, 05:18 pm »
Got mine today  :D
After 5min Im glad to report it is not sibilant or sharp in any way .
Will compare it to Bda1 in the weekend .
Ottawa HiFi
Re: BDA-2 DAC
« Reply #175 on: 25 Jan 2013, 03:12 am »
Thanks James.
I installed a MyDac from Micromega (loan).  It is sounding fine at this time in my system.
I am looking forward to receiving the BDA-2 once again and putting it through it's paces.
I know the Micro Mega is not in the same league, but it is also not replicating the initial sibilance I had before.
Tomorrow is another day and I will report back once I have installed it back in my system.
Again James, Team Bryston, thanks for being local (Canadian) and looking at my DAC in a timely manner.
Jules.
Re: BDA-2 DAC
« Reply #176 on: 25 Jan 2013, 01:05 pm »
Thanks James.
Jules.
Hi Jules
Given that you preferred the sound of the BDA-1 do you want me to replace the 2 with the 1 for you?
james
gordon
Re: BDA-2 DAC
« Reply #177 on: 26 Jan 2013, 02:29 pm »
Got mine today  :D
I am now 10 full days into the BDA2 as a replacement to the BDA1 and am loving the trade up in sound quality. No knock on the BDA1, the 2 just takes it to a new level. Enjoy!
Ottawa HiFi
Re: BDA-2 DAC
« Reply #178 on: 26 Jan 2013, 03:46 pm »
James,
I will think about your offer.
From what other are generally saying, the BDA2 is a significant step up.
I will look at every component in my system, starting with my source to see where the sibilance is coming from.
I suspect the BDA2 is revealing the shortcomings of my $300 transport (the Squeezebox touch).  That's a good place to begin.
I appreciate your comments.  And James (from Bryston), thanks for your extra attention to my DAC.  I know you are pulling double duty this weekend
to listen to it.  Look forward to your remarks on Monday.
Ottawa HiFi (AKA Jules).
Xinon
Re: BDA-2 DAC
« Reply #179 on: 26 Jan 2013, 04:45 pm »
I Get mixed results when comparing them side by side . But one has played thousands of hours , the other only 50 . Both are spectacular soundwise ,but  Bda2 is a little constrained making vokals a little more distant, and the bass is a tad drier (harder) and does not go as deep , I feel the bassthump in the chest more with the Bda1 .
I had to check the specification to see if they had the same output voltage ,because I felt the Bda1 was louder . Bda1 makes rythmic music swing more ,it has more PRAT , Bda2 is a bit more focused/controled( maybe) an relaxed .
Tonaly they are very similar .
I will let the Bda2 play for one more week and check again next weekend, but I am not returning the Bda1 just yet as it is still my favourite, but it is close.....
Music used in this comparison .
My little Angel - Blues Company
Blackjack hart - Michelle Shocked
Add fiction - Remi Panossian Trio
Fly me to the moon - Frank Sinatra
David Munyon - Hollywood town
Cheers from Norway  :D
And I blame all mispelling om IPad  :thumb:
