BDA-2 DAC and BDA-3 DAC
0 Members and 3 Guests are viewing this topic. Read 402082 times.
spitzer
Re: BDA-2 DAC and BDA-3 DAC
« Reply #1040 on: 8 Nov 2015, 04:17 pm »
Hi
That is not normal.
james
Hello, Thanks for your answer. So What do you think about faulty? Maybe transformer screw attaches to chassis loosen with Times, or main line ac with dc, what is your opinion James? Thanks in advance.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1041 on: 8 Nov 2015, 06:31 pm »
Hi
It could be either but I would try it on another power line and see if it still hums.
james
spitzer
« Reply #1042 on: 9 Nov 2015, 03:27 pm »
Hi
james
Hello again, ı tried it other power lines, but same result. Then ı measured vdc on mains, it was about 250mv. Nevertheless I dont know if it is reason.
« Reply #1043 on: 9 Nov 2015, 03:29 pm »
That is high - do you know if the unit you have is a 220V or a 240V unit?
james
spitzer
« Reply #1044 on: 9 Nov 2015, 04:53 pm »
james
Hello James, It is 220v unit.
« Reply #1045 on: 9 Nov 2015, 05:15 pm »
That may explain it - send an email to Mike at Bryston and ask if it can be adjusted to 240V - mpickett@bryston.com
james
Slam Dancer
« Reply #1046 on: 10 Nov 2015, 04:47 pm »
What is the specs for the power cables that comes with Bryston products?
I would like some shorter ones, just wan't to check that it is ok to change them out.
Tympani
« Reply #1047 on: 11 Nov 2015, 02:07 am »
SlamDancer,
Since the Bryston BDP's and BDA's are low-current devices, practically any computer type IEC cable should easily provide enough current capacity to deliver power. Beyond that, however, I feel that any digital component with high end aspirations would definitely benefit from a good-quality shielded cable with quality connectors. The market is full of high end cables sometimes costing more than the components themselves. And yes, I'll admit I have drank the high end cable Koolaid with my components. But I think excellent results can be had from solidly engineered cables from value companies such as DH Labs, where a 3' Encore power cable will cost you about $100, and give superior results over the stock supplied cords. That's just one of many, many options. You might want to consult The Cable Company for trials. I think you will be surprised at audible differences between cables.
Phil A
« Reply #1048 on: 11 Nov 2015, 02:43 am »
SlamDancer,
Great advice
Slam Dancer
« Reply #1049 on: 11 Nov 2015, 11:13 am »
Thanks.
I just want to get rid of some of the cable mess behind my rack. So no need for super Hi-end stuff here, but good quality cables with lenghts approx. 0,5 to 1 meter is what I need.
Just wanted to be sure I'm not doing anything wrong or will make problems with warranty etc.
(Poor English, but I hope you understand what I'm trying to say) :wink:
« Reply #1050 on: 11 Nov 2015, 11:17 am »
Hi
No concerns with warranty using different power cords.
james
Slam Dancer
« Reply #1051 on: 11 Nov 2015, 12:39 pm »
Hi
james
Thank you.
Ansum
« Reply #1052 on: 11 Nov 2015, 01:37 pm »
I've been wondering about how a simple passive type of preamp/volume controller might perform compared to an active one when used between a BDA-2 DAC and a 4BSST2 power amp. As I understand it the output of the BDA-2 should be high enough that all one really needs from the volume control is attenuation and not amplification (right?).
There seem to be quite a few options for passive preamps/volume controllers from simple potentiometers like the ones below....
https://emotiva.com/products/electronics/control-freak
http://www.tcelectronic.com/level-pilot/
...to more sophisticated and expensive solutions like TVC and LDR types of preamps like the following...
http://www.mfaudio.co.uk/Menu2/preamplifiers.htm
http://www.tortugaaudio.com/passive-preamps/
All I really need a preamp for is to control the volume and ensure a good interface between a single source (BDA-2) and my power amp, so a minimalistic approach is fine with me as long as the sound quality does not suffer.
BrisbaneTom
« Reply #1053 on: 26 Jan 2016, 03:18 am »
Still working on it but it will exist.
james
Hi James,
I was wondering if you could give a rough idea of when the new CD player will be available?
Tom
« Reply #1054 on: 26 Jan 2016, 03:25 am »
Hi James,
Tom
Hope to show it at the Montreal Audio Show in March
james
BrisbaneTom
« Reply #1055 on: 26 Jan 2016, 03:56 am »
james
Excellent, thanks James.
Grant Hill
« Reply #1056 on: 26 Jan 2016, 10:29 am »
Wow great news!
werd
« Reply #1057 on: 26 Jan 2016, 03:54 pm »
Not a problem, any BDA dac can drive a passive. Used a BDA2 TVC into a 14B with no problems. I want to try one of the Tortuga passives. It's just the sound of a passive and not a line stage you have to get use to and decide whether you like or not.
rollo
  • Rollo Audio Consulting -
« Reply #1058 on: 26 Jan 2016, 04:22 pm »
  Passives require two things to make all sound its best The CDP or DAC  needs to have an output of 2V minimum. More the better. The amps input sensitivity should be less than 1mv. Cable runs should be as short as possible to amps as well.
  I find most passives lean in character except transformer based ones. Slage Autoformers and Promithius come to mind. Top of the heap would be Billington transformers in silver oh my !.
charles
srb
« Reply #1059 on: 26 Jan 2016, 04:46 pm »
That would be a catastrophic mismatch!  Input sensitivity < 1V ?
Of course that would suggest that none of the Bryston power amplifiers would be optimal.
