How to hook up subwoofer to BP-26P in 2.1 system
0 Members and 1 Guest are viewing this topic. Read 1658 times.
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« on: 5 Sep 2012, 01:10 pm »
Hi,as I am new to audio,I have Klipsch RW-10d subwoofer and a bryston BP-26P,I would like to now how to hook up sub in a 2.1 channel system,other speakers are Klipsch RF-35 for stereo speakers
drummermitchell
Re: How to hook up subwoofer to BP-26P in 2.1 system
« Reply #1 on: 5 Sep 2012, 05:52 pm »
With my 26 I went R+L XLR cables out of 26 an Y's on each side that went to each mono block and sub.
I see that sub is line level(RCA) or speaker level,I imagine you could use an adapter from XLR to RCA.
Uptown Audio
    • http://www.uptownaudio.com
« Reply #2 on: 5 Sep 2012, 06:53 pm »
Just use the RCA preamp outputs to the stereo inputs on the sub. I have an SP1 which I will likely be selling and I use it in a 2.1 system myself. It has both pre-out as well as a sub out with crossover function plus many other set-up options not found in the stereo only preamps. For two channel sound, even with a sub or a pair of subs, set-up is just the same as with a stereo preamp. That is that the main outputs can be used as sub outputs, you just have to use the crossover on the sub to control the frequency balance in room.
-Bill
drummermitchell
« Reply #3 on: 5 Sep 2012, 07:12 pm »
The BP-26 has only Balanced out(XLR) I believe.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 5 Sep 2012, 07:16 pm »
HI,
The BP26 has 2 sets of stereo RCA outs as well as 1 set of stereo XLR outs.
james
drummermitchell
« Reply #5 on: 5 Sep 2012, 07:21 pm »
Nice catch James,I've had my 26 for a few years and didn't even notice :duh:.
turnovertherecord
« Reply #6 on: 6 Sep 2012, 12:07 am »
Thankyou rca out R&L to sub R&L,works great,thanks again
Vaprak001
« Reply #7 on: 22 Nov 2015, 09:44 am »
Hi,
Just to make sure I've got this straight. I have a BP26 using XLR out into a pair of 28b sst2's. If I want to add a sub I can just run an RCA L&R out simultaneously? I don't have to move all outputs to RCA right?
PGS3038
« Reply #8 on: 22 Nov 2015, 01:32 pm »
A Bryston 10-b sub crossover will do a better job than y-splits and provides a much more controllable solution, with it's support for a dedicated mono sub. It is more expensive than Y-leads, but then there's no risk of reducing the separation between the L and R feeds, plus you'll get full control of the crossover settings, and you'll remove the bass load on your power amplifier, enabling higher spls.
« Reply #9 on: 22 Nov 2015, 02:58 pm »
Hi,
Hi
Yes you can hook it up that way but it is a FULL range signal being sent to the Sub - so crossover frequency and rolloff and level have to be controlled from the Sub controls.
Also the mains are still running full range frequencies as well.
james
Vaprak001
« Reply #10 on: 23 Nov 2015, 10:30 am »
Thanks for the replies.
Based on the info, I'm not sure I'll take the risk of the new sub though - it may sound a bit muddied without the crossover, and too expensive with. Saves me having another difficult conversation with my wife anyway.  :thumb:
PGS3038
« Reply #11 on: 23 Nov 2015, 01:33 pm »
If the sub is designed to go with the mains, then would the crossover function match their roll-off? There may be a specific setting from the manufacturer for this purpose.
