0 Members and 1 Guest are viewing this topic. Read 47200 times.
If a tube amp site not show underside images, the amp do not use hand wiring, it use PCB for mass production.
Not necessarily. I have seen hand wired tube amps with messy looking wiring, sloppy solder joints, wires passing through tight clearance drilled holes without grommets and cheap capacitors. If that were my mess, I wouldn't want to show photos of it either. Steve
I think the problem with high non-OTL tube powered amps is the output transformer. Pretty hard to find that large of OPT that doesn't have tons of parasitics leading to rolled off highs. A whole lot easier to make a OPT for 50-100w then 500w. There are companies like McIntosh that do a whole lot of trickery to get around such issues, but that gets complicated and those special transformers are going to be quite expensive in small quantities.
Wow impressive amps.In what application you use these amps?
