0 Members and 1 Guest are viewing this topic. Read 11361 times.
I took off the SurgeX cover to replace the PC with a 12g mil spec cable I built.It looks ok inside, but there are a lot of issues. First, steel connectors... there are quite a few, and a crimp type splice connector with a steel blade on the incoming neutral wire to couple it to the rest of the internal wiring. There are steel spade connectors going to and from the PCBs and power switches. All these need to go eventually... The receptacles used internally are mediocre and plated, these will need to be replaced with better units. Also, most of the receptacles are switched, which is feature I am going to eliminate by bypassing the power switch so the unit is always on while it is plugged in. There are also some passive parts that could be upgraded. Wires are PVC insulted copper, typical cheap hook up wire which could be replaced with mil spec wire without it costing much $.Overall, I think it is a decent unit but maybe not suited for really picky types, which you probably are if you are reading this forum... it should be interesting to upgrade the connectors, receptacles and internal wiring and see what kind of improvements it will make...
By doing these mods what do you think you will accomplish other then take what might be a UL listed product and void that cert?
Lol, I have designed and built a UL approved electronic control panel with 30 kW going through it before, so I'm not too worried about the safety end of it... Anyway, by getting rid of magnetic metals you will reduce distortions in the AC signal, which get through to the music signal. The results are likely to be a reduction in harshness and glare, revealing better detail and less listening fatigue. Hospital grade receptacles offer a better contact with the plug, which is also a big plus because it reduces resistance. Anytime you can get change out a relatively poor conductor (especially a magnetic metal) with a better one, it makes a positive change whether it's in the power supply or the signal path, which ultimately are the same thing. IMO steel connectors are the worst thing you could possibly have in any of your components, including power conditioning.
You better tell the manufactures of power transformers to find an other way to manufacture them!
If you decide to audiophile your SurgeX, I hope you'll update your results here in this thread, preferably with before & after pictures. I agree with Early B.'s thoughts, it wouldn't surprise me if you had positive experiences if you proceed with these mods. Good luck Dave! Cheers,Robin
Plus it's just plain fun to do.
