0 Members and 1 Guest are viewing this topic. Read 199361 times.
How long does it take to charge? Do you happen to know how many amp hours does the supplied pack have? Also, are there 24 vdc battery packs with more amp hours you are aware of off the cuff? Thanks!
The 24v battery thing is the thing I would need to figure out if the amps works out. I need a solution that is low maintenance. Aren't there chargers that can stay plugged in 24/7?
This is low maintenance as far as I have experienced. I ususlly get a full week on the battery running it 2-4 hours per night. I plug the charger in on Sunday night before I go to bed.But even on amps that you can plug the bettery in 24/7, I still hear a subtle hardness from the AC line. I prefer a no charger hook up to the amp for the best sound.And Freo-1, it seems that many of the Lithiums puts out 25-27V. I am going to still try one as soon as I can. Those that say capacitor banks improves the sound hooked up to a battery, I am anxious to try that out too.
Makes me wonder if a dedicated outboard linear power supply would also work well?
Thanks Tom. You're using 2x 5Amp 12v, right? (sorry too lazy to read thread over).
I could not tell the difference between a battery and a good linear PS in my digital amp. Both were huge improvements over the stock switching PS. I guess that's one way to save $ building an amp... don't include a decent power supply. @Ozark Tom, I think the best way to do batter power is probably going to be a LiFePO4 battery at 25.6 V with a voltage regulator set at 24V and some output capacitance. The voltage regulator shouldn't get too hot shunting 1.6V out of 25.6... You would need to build a simple circuit for the voltage regulator and cap bank, unfortunately, I am not enough of an expert to draw up a schematic for you, but I'm sure you can find what you need at diyaudio. An alternative would be to buy strictly 12V batteries like the motorcycle battery I linked to and a cap bank with no voltage regulator. Usually 12V auto batteries put out ~12.4V so you'd get just under 25V which will probably be ok, especially if you've already been running it with 2 12V SLA batteries already.
Jan also encouraged me to try that 24V K2 Energy Lithium battery, he feels that it will not blow the fuse. But since I only need about 5 watts to blow my head off, I might try this 12V first since it is only $95 on Ebay.http://compare.ebay.com/like/370502992418?var=lv<yp=AllFixedPriceItemTypes&var=sbar
For some, like the Posituve Feedback review said, the amp does sound good with the AC switching suppy. The TNT review said it beats the Dayens Ampino and I can vouch for that since I had one here at the time with the Murdorph oil cap and Alps volume control mods. And Jan at TBI encourages anyone to mod the amp to your liking.But on my system, the battery improves it by about 40%, and that is quite a bit by my standards.Jan also encouraged me to try that 24V K2 Energy Lithium battery, he feels that it will not blow the fuse. But since I only need about 5 watts to blow my head off, I might try this 12V first since it is only $95 on Ebay.http://compare.ebay.com/like/370502992418?var=lv<yp=AllFixedPriceItemTypes&var=sbar
I’m still wondering if a well designed linear power supply would work as well. I think it would need a lot of filtering, but could be worth looking into for those who do not want to mess around with occasionally charging a battery.
Tom, I think you being kind to the AC power supply. To date, with my system, the battery is closer to 80 to 90 per cent improvement in performance (it’s that dramatic). The difference in soundstage, clarity, 3D, and HF is remarkable. On the battery, vocals remind me of a good tube SET, while on the AC, not so hot. I’m still wondering if a well designed linear power supply would work as well. I think it would need a lot of filtering, but could be worth looking into for those who do not want to mess around with occasionally charging a battery. I’ll be submitting a more detailed review at the end of the week, but so far, the amp on the battery has FAR exceeded expectations, and I would heartily recommend to anyone who has a low power system setup to give it a serious audition.
Here is a good source on power supplies. Jan at TBI says that this is the place they use. http://www.batteryspace.com/The only problem with using an AC power supply with this amp, it is so revealing that battery will probably win out every time.
Which speakers are you using?I have most of the parts needed to whip up a basic linear power supply. I'll see if I can do a comparison.
I'm not so sure about the battery winning out every time. I have a cdp plugged into the wall, and then I have that going into a battery powered LDR attenuator, and that into a battery powered Virtue Two.2. I'm all batterie'd up. In a few days I'll have the Ncores with their advanced switching supply, that by accounts, is so good it doesn't even need power conditioning. So I'll be listening as truthfully as I can, I'll be listening hard to see if a battery powered supply is the best no matter what. I also have a Linear supply I can compare to as well. Looking forward to hearing this TBI, but maybe some of you more technical people can answer this: It appears to me, if this TBI is an indication, that Tripath amps sound better the less wattage you force from them. Because otherwise there's no reason why this TBI has to only be 32 watts. The Virtue is probably just as tiny, but pumps out nearly twice that amount. I will of course, compare those two amps, the Virtue and the TBI (probably the fairest, most apples to apples comparison of this shootout).
