0 Members and 1 Guest are viewing this topic. Read 199387 times.
The amp takes about 100 hours to fully break in. The amp never sounds harsh, but it will open up as it beaks in.I have two SLA 12v scooter batteries hooked in series for 24V and a 24V smart charger. I forget the brand.With the battery, the noise floor drops and you hear more detail. This results in more tranpaency, more depth, and a bigger soundstage. Small background details are also more noticeable.The 24V is going to give you 32 watts per channel, the 12 V will probably give you about half of that.Cardas posts improved the amp by about 30% fom top to bottom. It also added more magic with a bigger soundstage.I have never heard it clip, even when I had the 88db Classico 3's here. But I never play my system much past the 95-98db levels. I don't want to lose my hearing.
No, I have never tried a capacitor bank. I am not a big DIY'er I am afraid. Just all thumbs.
Do you have a capacitor bank across the batteries? I have a Trends T-amp that I used to use with a 12v Optima yellow top SLA battery. If you put a 25V+ electrolytic (large) and some film caps (at least ~1 uF, more is better) in parallel between the + and - battery terminals it will make an improvement.
Would these wiring items work with the Amazon batteries and a 24 volt xlr scooter charger?Harness:http://www.monsterscooterparts.com/ba24vowihaki.htmlPort:http://www.monsterscooterparts.com/xlrcooffboch.htmlJeff
Something like this ?
Here is a 24V Lithium that I almost bought, and it includes the charger.http://www.amazon.com/High-Power-Battery-Pack--BX2488/dp/B0064BM0Q6/ref=sr_1_14?s=electronics&ie=UTF8&qid=1343603926&sr=1-14&keywords=24v+lithium+batteryAnd the specs on this battery looks incredible, but it is $359.http://www.batteriesinaflash.com/specs/LifePO4/K2B24V10EB/K2B24V10EB.pdf
If everything go as planned I have ready modified RWA Black Lightning running at 12V. Cheers Ritchie
It would be interesting to compare an optimized battery supply like the RWA to a regular battery, I bet the RWA unit will be a significant upgrade. You could just pull your car up to the amp and get the jumper cables out...
I am using a Dodd battery pack, but all it is, is 2-12v scooter batteries tied together and hooked up in series. The power cord can even be reversed in polarity and it will not hurt this amp. A 24V smart charger is used to charge the battery. I have found out the hard way, unhook the charger before you turn the amp on. The charger puts out more than 24v and will blow out the 4 amp fuse inside the amp.This amp is almost bullet-proof. The company took a lot of strides in using the highest protection methods that they could.On Amazon, here is the best deal on 2-12V batteries for $15.92.http://www.amazon.com/gp/product/B007PT865A/ref=ox_sc_act_title_1?ie=UTF8&smid=A24WV2YRRJEBAG
How many hours of play out of the SLAs before needing to charge?never mind found the specs tab at the bottom of the product page.
