0 Members and 1 Guest are viewing this topic. Read 24909 times.
My understanding was that was the best setup for getting improved SQ playback?
If i chose the ministack itunes library to play music instead of the macmini, would i need to have a copy of audirvana plus in there also?
Now the only thing I need to figure out is how to get my other external hard drive to back up the one I load music onto. I read something about time machine but it looks like it backs up the entire computer and not just the music. Maybe that’s not a big deal, any thoughts on this?
John R, Well the Mini Stack 2.5 as a back up is fine, but it is way too noisy to use as the source for my music. My daughter said I should just make a playlist and put it on a 64 gb usb stick. Would a USB stick be ok for good playback? My music is AIFF so I think I should get up to 90 albums on one.
It works! And it works well , sounds fantastic!
That's what I was thinking of doing with Audirvana Plus. Had a try on a 1gb stick and it played onto A+ in memory mode. Just double clicked on the first song and it played the entire album. Didn't hear any difference from internal drive but if its going to ram memory,(6 of 8gb allocated to A+) then I suppose logically it would sound the same?
Has anyone by chance used the something like the Rii Touch remotes http://riiminikeyboards.com/ or the Mobile Mouse application http://mobilemouse.com/ to control their headless Mac mini?For me, that's the worst part - using the Mac mini as a music and entertainment server would mean having it hooked to the TV. The operating system is designed to be used with a keyboard and mouse, though. If it could be controlled without a keyboard and/or mouse, it would be great.
Excellent But won't your daughter want her MacBook back?
