What ohm rating of the driver (dynaudio 17w75) in the Quartz 3 way
0 Members and 1 Guest are viewing this topic. Read 2800 times.
marksrent@gmail.com
Hello all,
I am fixing up a old pair of Quartz 3 ways. The  17w75 that come with the kit are a 6 ohm model is that correct ohm rating. When  built the kit back in 88 I didnt notice. Now I have to replace the woofers and I want to make sure I am using the correct one.
thanks for any help  mark
Mike Dzurko
Seems to me that Dyna called it a 6 ohm driver even though it spec-ed out pretty much like everyone else's 8 ohm drivers. I think Dyna was just trying to be more honest in saying the 6 ohm rating was closer to what it actually was . . . .
marksrent@gmail.com
Thank you Mike for the fast responce .
mark
Chris Colhoun
  • Guest
Hi,
Sorry to dig up an old thread but would someone be able to tell me were I could purchase the cheapest replacement driver for the Dynaudio 17W75?
I have a pair of old Audience 60 speakers and one of the 17W75 woofers has been damaged... alternatively would I be better replacing both woofers (there is one in each speaker) with a set of equivalent or better drivers (that would be the correct spec to work with the existing cross overs)?
(To purchase an original replacement from Dyn I am looking at about $400 + shipping. (I am in Australia)
Cheers
Chris
Mike Dzurko
Chris, I think I'd try one of two strategies:
1) Check with Meniscus and Madisound to see if they could repair/rebuild the damaged driver
2) Check various DIY forums and classifieds to see if you can find a good condition replacement or pair
Best of luck!
