0 Members and 1 Guest are viewing this topic. Read 16213 times.
Very interesting! TY.This version doesn't have a GDT, like the Teflon version? What's a GDT? I'm building a Felix ...ahem...what's a Felix?, but the caps between the choke and outlets will be Jantzen Superior and Mundorf Silver/Oil.Did you found that Mundorf sound much better than Auricaps? No; it was in my system only a few hous before I started improving it. I'm not a GEA who recognizes tiny differences quickly; I'm much more a medium- and long-term listener who eventually hears larger differences in the quality of the music. I chose the Mundorfs for their sound quality, metalized construction (meaning they're 'self-healing', which actually means self-diminishing), and very high Voltage rating.
Quote from: rdsu on 8 May 2012, 07:44 amThis version doesn't have a GDT, like the Teflon version? What's a GDT?
GDT means Gas Discharge Tube.From your words, Audience use different capacitances in USA and Europe.In Europe they use 0.1uF for digital sources, 0.22uF for analog sources, and 0.47uF/0.56uF for power amps...
Nice job! Any sense for the CMC type/brand/rating Audience is using?Thanks Jim
Yes, gas-discharge tube...I figured that out at lunch today. Yes, it does.Don't know what caps Audience uses in their European versions. My ar12 contained pairs of 1uF, 0.68uF, 0.47uF, 0.33uF, 0.22uF, and 0.1uF caps on the 6 outlets.
TYVM. Too many undefined initializations for me today, I guess--what's a CMC?
What is the capacitance of the big capacitor close to copper bus bar?
The cylindrical black thing next to what I presume is a GDT is a 50K, 5W resistor, perhaps to discharge the caps.Common-mode choke, huh? I believe the ferrous ring wound with AC (input) cable at the right of this pic......is the CMC.
Any chance you want to cut into the shrink to see what they are? The Audience advertises the fact that they are non-current limiting so I'm very curious to hear what CMC they use.Jim
Do you already have the final result?
Well, I finished working on it, so that's finished.As I indicated above somewhere, IF IF IF I'm a GEA, I'm a long-term GEA, not a 'quick' GEA. I've not plugged all the frontend equipment into outlet strips to determine if I can hear the effects of removing the '12 from my system, but I do know one thing--my system has never sounded better, overall. 'Better' in my case means larger soundstage and harshness of high frequencies at least reduced if not gone. MAYBE I'm getting about the same results from my c.-$2500 p-con as the next guy gets from his $9K aR12-TS...and maybe not, but I know that mine is NOT coming out of the system. One thing yet to do is to replace the initial 'pigtail' with Neotec stranded UPOCC-copper, the original ferrous ring* with another ferrous ring, and the crimped ringterminals with Audioquest silver-over-copper spades, all so that I can make better connections from the Furutech cable to the inlet pigtail. (John McDonald refused to make a longer one for me.) I hope to find and use 8g. crimpsleeves but haven't yet looked for any.Anyway, I LOVE the sounds of the music coming out of my system with this in it, and all the above is money and time well spent.* which started to flake apart while I was soldering and taping the connections
