Mac OS and hardware tweaks
0 Members and 1 Guest are viewing this topic. Read 36898 times.
audioengr
« on: 30 Apr 2012, 01:38 am »
Here are some software tweaks that make a significant difference in SQ with Mac OSX (I'm staying with Snow Leopard):
Download the file here:
http://www.ultrafi.biz/
I have also been told by many that putting a SSD like these in the Mac Mini makes a big difference, even to the older DC powered ones like I have:
http://www.ssd-for-mac.com/mini-upgrades/sata-ssd.html
http://eshop.macsales.com/shop/SSD/OWC/
or:
http://www.amazon.com/Crucial-2-5-Inch-Solid-State-CT128M4SSD2/dp/B004W2JKZI/ref=sr_1_1?ie=UTF8&qid=1335749763&sr=8-1
I have also heard that improving the power supply for the newer AC-powered Minis makes a big difference (by removing the switcher and using an external supply), but I'm not convinced that changing the floor-wart on the older Mini makes a significant difference.
Steve N.
« Last Edit: 30 Apr 2012, 03:53 pm by audioengr »
rpf
Re: Mac OS and hardware tweaks
« Reply #1 on: 30 Apr 2012, 02:01 am »
Thanks Steve.
audioengr
« Reply #2 on: 27 May 2012, 03:51 pm »
Compared a 2011 64-bit Mac Mini with i7 Snow Leopard (also with no AC supply inside - external DC supply), SSD, 8GB DRAM to:
my older 32-bit 2009 Mac Mini with standard floor-wart supply, Snow Leopard, SSD, 8GB DRAM. Both using Amarra 2.3.2 4319, and stopping all unneeded apps, ala Mach2music.
The older Mac wins.  Better high-end extension.  More live on Piano and strings.  This is what I'm using at Newport Beach show.
Steve N.
Davo50
« Reply #3 on: 27 May 2012, 06:29 pm »
Why are you sticking with Snow Leopard?  Wonder how that comparison would go with Lion on the 2011?
audioengr
« Reply #4 on: 28 May 2012, 01:00 am »
I have not hear Lion yet, but I seriously doubt if it will fix the SQ with the newer Mac.
Steve N.
Crimson
« Reply #5 on: 28 May 2012, 03:13 am »
I have not heard Lion yet
Well, maybe you should?  Wink2
Watthead
« Reply #6 on: 18 Aug 2012, 12:19 am »
When i go to the webpage it seems like its a webstore? Can't seem to find a place in it where to download a file. Can someone gimme a hand here?
abernardi
« Reply #7 on: 18 Aug 2012, 01:35 am »
Steve N.
Steve, do you have any theories as to why?  I'm assuming this is USB, not toslink?
audioengr
« Reply #8 on: 18 Aug 2012, 01:37 am »
These tweaks will be available on apple.com in iBooks.  These titles:
The Audio Optimization Guide For Apple For Apple OS X - Mountain Lion
The Audio Optimization Guide For Apple For Apple OS X - Snow Leopard
Steve N.
« Last Edit: 20 Aug 2012, 07:13 pm by audioengr »
audioengr
« Reply #9 on: 18 Aug 2012, 01:40 am »
Here is my theory:  Slower CPU, slower front side bus and faster better USB ports and controllers.  DC-powered.
Probably all of the above make a difference.
Steve N.
rubenpp
« Reply #10 on: 11 May 2013, 08:00 pm »
Just got a Mac Mini (late 2009) last night and replaced the hd with an SDD and added 8gb of ram.
I can see or hear rather why this is better than the newer mac minis ( got a 2011 model to compare) .
Highs are definitely more extended , and the sound seems a bit more natural.
Will try out the OS tweaks later to see if there's more improvement.
Ruben
